rad shroud
There is no radiator shroud on my 1972,307 v8 c10.
Wondering if other year shroud. except '72 will fit. |
Re: rad shroud
You have 3 choices standard radiator small block , H D radiator with small block, 4WD with small block. Hope this helps
Re: rad shroud
Do you have factory A/C?
Re: rad shroud
no A/C
Re: rad shroud
For a small block in our trucks, there are 3 different shrouds. One with a/c, one without a/c, and one for 4wd's. The years are interchangeable.
Re: rad shroud
I have a stock one you can have if you want to give up those blue floor matts?? :)
