69 C-10 Suicide doors
Ok guys I need your help. I was talked into a project that several other people started, A large basket case! This truck is completly apart. Rolling chassis is done with cab sitting on chassis. rockers and cab corners welded in wrond and original door hinge holes welded up. no original hinges and one door badley hacked up. The prior bodyshop gave up and bailed. The hinge kit is a autoloc. since I have no real starting base to start fron ( original hinge points) can you guys offer any pics, measurements drawings prayers drinks or any other suggestions and help I would be greatful. Before you suggest another cab. don't, I already tried. this was his dads and he wants this cab. Thanks Tim.:uhmk:
Re: 69 C-10 Suicide doors
Post up some pics and you will have better luck with suggestions on were to go.
Kevin LFD Inc. |
Will get some pics in the morning.
Here is a suggestion for suicide doors. If you are thinking of continuing with those. This is a GT Factory kit that I have been working on.....I dont have any up to date pictures after paint.
http://i295.photobucket.com/albums/m...9/DSCN1159.jpg http://i295.photobucket.com/albums/m...9/DSCN1162.jpg Its on a Honda Prelude, just look over that! But it is a one hinge kit and will hold up alot of weight.... This is the site: http://www.gtfactory.jp/180.htm |
