!966 C-10 Drums
I am trying to change my six lug rear drum into a 5 lug and i was wondering if i could just simply change just the drum part were the lugs are located?
MARRY CHRISTMAS!! |
Re: !966 C-10 Drums
the lugs are on the axle itself. you would have to swap them or redrill for 5 lugs and use 5 lug drums. pretty sure thats right. can anyone confirm?
Re: !966 C-10 Drums
Correct indeed, Grasshopper.
Re: !966 C-10 Drums
Have to do a complete rear swap or replace the axles. here is a fairly priced kit from CPP
http://www.classicperform.com/Store/...k/6569RACK.htm |
Re: !966 C-10 Drums
thats the thing the lugs are not on the axle they are on the drum part. if i take the drum of the lugs come off.
Re: !966 C-10 Drums
Something doesn't sound right here. On a C10 the wheel studs are pressed into the axle flange. Is the axle and all coming out with the drum? You can convert to 5 lug, but you first have to change out the axles to aftermarket 5 lug axles. Then you can upgrade to the larger 5 lug brakes by changint the backing plates, drums and all internals. This should be able to be found at a local wrecking yard.
Re: !966 C-10 Drums
Re: !966 C-10 Drums
what model rear do you have? it sounds like its not a 12 bolt.
Re: !966 C-10 Drums
Me thinks we're havin' terminology issues here
The brake drum is just the the "capped tube" about 11 by 2 inches on the end of the drive axle. the drive axle holds the wheel studs (another missname because they are spline cap srews) Any production 1/2 ton rear drive axle assembly (also shortened to axle to add to the confusion) that I, and I would guess most of us, have seen have the wheel stud drawn thru the axle shaft's flanged end. 6 bolts were mentioned which on a 66 chev or canadian GMC should indicate a semi floating GM corporate 12bolt (named for the 12 bolt cover pan) Does this put us all on the same page???:mm: |
Re: !966 C-10 Drums
CPP for the front and a Trans/Am rear end swap 4 wheel disk - that the ticket - if interested I can walk you thru it
Chow Eric |
