Show your motor...
Lets see some of your engines you have built, installed, or are currently building. With a little description.
Re: Show your motor...
http://i1003.photobucket.com/albums/...00428-Copy.jpg
64 SS IMPALA 327 +.040 |
http://i1003.photobucket.com/albums/...A/IMG00468.jpg
73 454 HI PERF/TRUCK +.030 W/CROSS DRILLED FORGED CRANKSHAFT |
406 I had built for my 67 Camaro
http://www.fquick.com/images/vehicle...5443190415.jpg 406 Small Block Chevrolet 510 HP 506 FT LBS Torque .030 canadian casting 400 block 0 deck height align bored lifter bores trued up and bronze sleeves inserted. eagle 4340 forged steel crank eagle 5.7" h-beam rods wiseco pro tru flat top pistons comp cams xe 284 cam comp cams 1.6 promagnum roller rockers comp cams chrome moly push rods AFR 195 Eliminator Heads 65 CC L-98 style gmpp chevrolet competition valve covers edelbrock super victor intake 750 holley street hp mechanical secondary carb Mallory HEI distributor Accel 300+ race wires 6 " ATI super street damper Melling M-Select High Volume Oil Pump Hamburger 7 quart oil pan w/windage tray and crank scraper arp fasteners 350 I put in my 69 C/10 http://i222.photobucket.com/albums/d...g?t=1261898459 pretty much a stock crate 350, edelbrock performer intake, hei and a 600 single line holley. |
3 Attachment(s)
Here's mine, original 4 bolt, high nickel-350.
Now a 383 stroker- more info on in signature. s/t |
Sport truck, I love those valve covers!
First motor i've ever built :chevy:
http://i93.photobucket.com/albums/l6...Forsale005.jpg |
5 Attachment(s)
Here's my 350 I put together last April. 350 bored 0.30. New crank, aluminum pistons, will have to locate the exact specs on the cam, a bit beefy but not stupid, this is my driver afterall. The heads are off the old 283 which I had redone a few months prior to this build.
s/t |
2 Attachment(s)
heres a before and after.
361 sbc patriot vortec heads 2.02-1.60 64cc 9.5-1 comp comp cam 280H .480.480 SS full roller rockers hurricain intake speed demon 650 carb This is the second motor I built but cant find the first ones pics. |
3 Attachment(s)
My original 350.
3 Attachment(s)
New Ramjet 350
My first ever motor that I rebuilt my self and installed it. 305HO with over 200,000 on it now. Did the 700 R-4 too.:chevy:
http://216.77.188.54/coDataImages/p/...1/DSC01187.JPG http://216.77.188.54/coDataImages/p/...1/DSC01188.JPG |
Yeah sport truck those valve covers are very nice..
Hey bobo, how do you like the 283 heads on that 350? Does it run good? Keep the pics coming guys. They give me motivation to do some of the ones i have. After the 454 and 327 i will be starting on a 97 vortec 350 zz4 and 1970402 bbc. Pics on the way |
3 Attachment(s)
Heres One I just Finished 355ci Edilbrock Heads, Roller Rockers, Keith Black Pistons, Nice Cam, Airgap Intake, Msd
383 with Edelbrock tune port injection
2 Attachment(s)
Here's mine!! GM Performance ZZ383.
This is the motor going in my truck...350 4 bolt main crate motor. Got a real good deal on it from craigslist, motor and trans for $300. Took it apart and was like brand new inside, did the oil pump, timing chain, crane cam and rockers. Got a 3200 torque converter with a 400 trans and 12 bolt main.
Here's a 427 with 3 two's
5 Attachment(s)
Small Block "406" ;) with Eagle internals, aluminum heads, air gap intake, HP 600 holley, MSD dist and Box....
here is a crappy cell phone video of what it sounds like....It hauls ASS!!!!:metal: |
s/t |
4 Attachment(s)
Heres my 383:metal:
what kind of headers are those bronze70?, Those look RAD!!!
