$450 find
Ok i know its ugly but im in it for the stuff under the hood and the trans.
the guys said she had not been ran for a few years. maybe close to 2000. the gas smelt like it was mixed half with water. after a few times of pulling the breather and pouring gas in carb it fired up and back fired a lil then started counting them off at a nice idle. edelbrock 750 and rpm performer intake. i dont know much about the rest but also has a power steering box that i will prob part with since mine has one. from my understanding the rear end has problems and is why the truck was parked. http://i10.photobucket.com/albums/a1...b/100_2171.jpg http://i10.photobucket.com/albums/a1...b/100_2173.jpg http://i10.photobucket.com/albums/a1...b/100_2175.jpg http://i10.photobucket.com/albums/a1...b/100_2177.jpg http://i10.photobucket.com/albums/a1...b/100_2178.jpg http://i10.photobucket.com/albums/a1...b/100_2180.jpg http://i10.photobucket.com/albums/a1...b/100_2186.jpg http://i10.photobucket.com/albums/a1...b/100_2187.jpg http://i10.photobucket.com/albums/a1...b/100_2197.jpg http://i10.photobucket.com/albums/a1...b/100_2190.jpg |
Re: $450 find
Looks like a nice one. Do you need the bed?
Re: $450 find
nope its available. tailgate looks good except for a rust threw line across the bottom of the inside.
Re: $450 find
while running i can see the flywheel spinning but when i change the gear shift nothing happens. the driveshaft also does not turn.
Re: $450 find
sounds good. I need to come over with my sawall and cut that top off.
Re: $450 find
also check the gear shift linkage and properly adjust it if necessary. |
Re: $450 find
also check the modulator valve, but it is a good buy. i would have paid 450 for it.
