Driveshaft spacer-SOLD
I have a one inch thick driveshaft spacer that I pulled off the front of a 208 case that was behind a 700R4 in a 88 model K5.I'm not sure what the original application/use was for this but it's either a store bought spacer,or someone took their time machineing it.$35 shipped.
Re: Driveshaft spacer
those are store bought......cheap way of lengthening the front drive shaft when you lift one.
Any idea if this will work for a 6 inch lift? If so i'm interested. If i remember correctly the bolt pattern should be the same as a 203.
I did a little research and this will work for what i need so i will take it. PM sent.
