Sand Blast Cabinet
ANyone have one of these?
http://www.harborfreight.com/cpi/cta...emnumber=93608 What else was needed if you bought it aside from a air compressor? how did it work? what media are you using on normal parts such as control arms etc. |
Re: Sand Blast Cabinet
I have one. It's decent, and has worked for me. You'll want a dryer, and probably some kind of dust removal. (I've just been using a shop vac) -- The instructions say not to use aggressive media like aluminum oxide (Go figure!) I've just been using sand (Gasp! I know, I know)
I have one, but like ^ said a good dryer, and some kind of dust removal. I went to TSC and bought there black diamond balst sand, not suppost to be as bad as regualr sand. but does a fairly decent job for the money spent.
i have one similar i use black beauty sand the fine grade its ok great for smaller stuff
I bought mine from these guys and have been very happy with it.
708 TL I also do firearm refinishing so I use aluminum oxide and have had no problems. |
I have a 20 yr old Snap-on blast cabinet. It came with a vacuum device, and I have a dryer on the line going into it. I have tried aluminium oxide, and like medium coarse glass beads best ( less dust ) . works on most all thing that will fit into the box.
