-   The 1967-1972 Chevrolet & GMC Pickups Parts Board (https://67-72chevytrucks.com/vboard/forumdisplay.php?f=8)
-   -   AR Misc Parts For Sale From My 67 Chevy Truck (https://67-72chevytrucks.com/vboard/showthread.php?t=382777)
es67chevy 01-23-2010 11:25 PM
I have various parts left over from my build I'm going to start clearing out. All parts listed with price shipped in the US. I accept Paypal or MO. Pictures below. I can provide additional pictures, info, etc on request. PM me if outside of US for shipping options.
67-72 Radiator Core Support Brackets - $15 Shipped
Rear Upper Shock Mounts - $10 Shipped
67-72 Window Handles w/ Black Knobs (3) - $10 Shipped
67-72 Passenger Kick Panel Vent (seal is torn) - $20 Shipped
Antenna Cable - $15 Shipped
SOLD - New Polyurethane Radiator Core Support Mount Bushing Set
SOLD - 67-72 w/o A/C Glove Box
SOLD - Rearview Mirror
SOLD - 67-72 Upper Door Hinges
SOLD - 67-72 Coil Spring Clamps (2)
SOLD - 67-72 Front Bumper Braces
The Pictures:
Radiator Core Support Brackets (Surface rust only - just need cleaned up) - $15 Shipped
http://i219.photobucket.com/albums/c...e/100_1051.jpg
http://i219.photobucket.com/albums/c...e/100_4393.jpg
es67chevy 01-23-2010 11:26 PM
Re: Misc Parts For Sale From My 67 Chevy Truck
http://i219.photobucket.com/albums/c...e/100_1046.jpg
67-72 Door Lock Set w/ 1 Key - $10 Shipped
http://i219.photobucket.com/albums/c...e/100_1053.jpg
http://i219.photobucket.com/albums/c...e/100_1057.jpg
http://i219.photobucket.com/albums/c...e/100_1058.jpg
http://i219.photobucket.com/albums/c...e/100_1042.jpg
http://i219.photobucket.com/albums/c...e/100_1043.jpg
too much stuff 01-23-2010 11:37 PM
Core support bushings should work for a 69? Any difference anyone knows of? I will take them if they work for my application. Eric
es67chevy 01-24-2010 12:10 AM
According to LMC Truck and Classic Parts, they both indicate the same kit for 67-72 Chevy and GMC Trucks. Let me know what you decide to do. Thanks!
Eric
es67chevy 01-24-2010 05:13 PM
Lots still left.
paul mora 01-25-2010 11:11 AM
Do you have a cig liter set up I need to install one in my truck ship to 92648
es67chevy 01-25-2010 03:05 PM
Hey paul mora, right now I only have what I've posted available to offer. I haven't went through all my parts bins yet, so its possible there's one I won't be using in there somewhere, but it may be a bit yet before I find out. I will definitely contact you if I find one within a reasonable amount of time. Right now, I'm just trying to stay organized on what I offer based on what I've taken photos of and dug out of my parts bins.
burb71 01-25-2010 04:15 PM
I'll take the mirror, let me know how you want to be paid
paul mora 01-25-2010 04:28 PM
Someone posted one today and I just bougght it
Thank for trying
es67chevy 01-25-2010 11:51 PM
Will send you a PM with pymt option details. Thanks!
es67chevy 01-26-2010 03:04 PM
Updated list bump
es67chevy 01-29-2010 12:41 PM
Friday Bump
IndyRich 01-31-2010 12:24 AM
Do you know if the upper shock mounts will work for 1/2 ton leafspring (that is what I need)......how does it attach to the chassis? Are those rivets that have to be drilled out to bolt through? Thanks
es67chevy 01-31-2010 01:29 AM
Hey, IndyRich. I'll do my best to try to help you, but not too familiar with what all changes in the rear when you go to leaf springs. May be someone else on here will read this and be able to confirm for us, but I will post a couple pics that may help you determine better if it is way different for the shock mounts or the same. On a coil spring truck, there is a brace that runs from frame rail to frame rail. In the attached pictures, it has the rubber hose laying over the top of it. Underneath that brace, these stock mounts are riveted on from the factory, set at a little bit of an angle. When you switch to an Early Classic drop kit, it comes with new upper shock mounts that are shorter, to allow for the reduced travel between the rails and the axle. You have to drill out the rivets in the stock brace. In the first picture, you can see the new bolts and nuts on the front of that brace. The second picture shows the bolts on the back of the brace along with the driver's side replacement upper shock mount bracket.
If you have that same brace running from rail to rail slightly in front of the rear axle, then I would assume leafspring trucks probably have the same setup for shock mounts. In order to mount these on your truck (assuming you have the same mounting location), you would need to finish drilling or grinding off the swollen part of the rivet still inside the shock mount. Then you would need to find 4 bolts the size of the holes in the brace and mounts. I could get the measurements of mine this week if that would help. The truck isn't here right now as it is in paint, but I plan to go by there this week.
Let me know! Thanks!
http://i219.photobucket.com/albums/c...s/100_0472.jpg
http://i219.photobucket.com/albums/c...s/100_0475.jpg
mup123 02-03-2010 08:18 PM
Hi,
If still available, I'll take the glove box, upper door hinges and the radio antenna wire. All items shipped together should cut the shipping cost. Shipping to NC 27028. Pls pm me your paypal info.
mup123 02-03-2010 08:27 PM
What capacity is the rear mounted gas tank? Is it new and what is it out of ? it looks pretty neat.
es67chevy 02-03-2010 11:35 PM
Originally Posted by mup123 (Post 3778154)
Hi,
PM sent. I believe the tank I am using holds 16 gallons and it is from a 49-52 Chevrolet car.
c10 friend 02-03-2010 11:55 PM
I'll take the front bumper supports. Can you send me a PM so we can make the arrangments. Thanks.
es67chevy 02-04-2010 12:46 PM
PM sent.
rads42 02-10-2010 10:38 AM
What's the story with the 383, home built? crate? mileage?
Eric
es67chevy 02-11-2010 02:21 PM
Eric
Hey there. Just had it built by an engine shop up in Missouri so no miles on it yet. Still waiting on the truck to be painted. It has a pretty aggressive cam too so should sound pretty good (sorry don't know all the details).
Using this as a bump as well. Parts still available as listed. Remember that price includes shipping.
rads42 02-11-2010 09:51 PM
Sounds good, I want to get a 383 for my '71 blazer just don't have the $$ yet. Good luck with it.
charlesratcliff39 02-12-2010 08:48 PM
I need the front bumper mounts how much shipped to 72150 ?
es67chevy 02-12-2010 09:10 PM
Hey C10 Friend, I've been attempting to contact you via PM and personal email but I have not heard back from you. If you still want these, you have 12 hrs to respond otherwise they are going to the next inquirer.
es67chevy 02-12-2010 09:11 PM
Hey there follow Arkansan. The price you see is shipped to your door ($10). I've got to give the other guy one last chance that said he wanted them and if he does not respond, they will be yours. I'll send you my paypal info via PM in the morn if he does not respond.
