dodge steelies
DODGE 1500 PICKUP 02-08 20" BLACK STEEL WHEELS ok will these fit the 73-87 chevy bolt pattern? i like the way these wheels look, and where can i find the for a decent price :devil::devil:
Re: dodge steelies
No they will not fit. It's a different bolt pattern so you will need to modify the wheel or run an adapter.
Re: dodge steelies
is there another steel wheel in a 20 that will fit this bolt pattern?
Re: dodge steelies
17 inch toyota FJ, there 6 lug, tcb has a set they look good!!!
Re: dodge steelies
What exactly are you after, a cheap 20 or a steel wheel? |
Re: dodge steelies
what's the bolt pattern on them anyways and where can u find a adapter 2 make these work
Re: dodge steelies
there 5 on 5 1/2 i was looking at getting some too, maybe an adapter would work but not to sure on how safe they are i already broke spacers before idk how the adapters would hold up.
Re: dodge steelies
o ya go to www.finishlinewheels.com and look under 07 dodge 1500 i think there like $95 apiece
Re: dodge steelies
i like the steel wheel look it fill real well, i looked in finishlinewheels and the bolt pattern said 5X5.5 is that not the same as 5 x 5 1/2
Re: dodge steelies
Your GM truck bolt pattern is 5 on 5.
Re: dodge steelies
Re: dodge steelies
Oh ok I see. Just did not pay attention lol. Thanks.
Re: dodge steelies
There was a guy in the 67-72 forum that was going to run a set. I "think" he had planned to use adapters, but that didn't work out because he had clearence issues with his stepside bed.
Don't give up if you really want them.They are a clean looking wheel. I think he bought his off of eBay and got them fairly cheap. |
Re: dodge steelies
ok so i found this site that sell adapters what will the chevy bolt pattern be in metric? is this correct chevy 5x120.7 to dodge 5x139.
I doubled checked it its 5 X 127. To 5 X 139. Please correct me if I'm wrong. |
Re: dodge steelies
let us know how much $ ya get in it completed id like a set
hows the safety factor on adaptors? whats the total look like tires wheels adaptors |
Re: dodge steelies
Check out sgtusmc's truck. He has the 20's for a Dodge.
He had to use adapters for them. http://67-72chevytrucks.com/vboard/s...&postcount=156 |
Re: dodge steelies
Just remember that an inch equals 25.2 millimeters when converting anything to metric.
Re: dodge steelies
I ordered a set of these things and should be picking them up next week (on the slow boat from the States to New Zealand).
I got them from a guy in texas called Novus Wheels for $190 for the set (from Ebay), I plan on getting them redrilled and powdercoated. The offset from what I can tell is +20 vs +10 for the stock rallye on a c10. I believe they are around 5.75" BS, if anyone knows different Id be keen to know. Ill be running 255/35/20 all round, Ill let you know in a couple of weeks if and how they fit. |
Re: dodge steelies
2 Attachment(s)
They look kinda cool with white walls on the 20 inch steelies!
Re: dodge steelies
^^^^ now that's s i c k!!
Re: dodge steelies
Yeah that looks cool, I was planning on getting my tires striped white aswell.
Re: dodge steelies
64shortc10 r u using any adapter 2 run those steelies where can i find sum i wanna pick up a set steelies real soon 4 my 69
Re: dodge steelies
Omg!
Re: dodge steelies
http://www.wheeladapter.com/index.php http://img.photobucket.com/albums/v1...k/101_5499.jpg |
Re: dodge steelies
