Project 6.0 (my '87)
Ok I've been using this site for a while now, figure its about time I start my build thread. To start off I've got an '87 GMC swb that I've had about 5 years now and it used to be my daily. Long story short it had motor problems, and i got a new car so this is now my project. My general plan is to get the 6.0 I have in the truck and back it by a 6L80. Pictures are next.
Re: Project 6.0 (my '87)
4 Attachment(s)
Here are some pics of it before I started a few months ago.
4 Attachment(s)
Here are some as i took the front end apart. I wound up finding a crack in the passenger side of the block under the center 2 exhaust ports.
My Vortec 6.0 LY6... now all I need is a 6L80 I can afford and to tie up a whole lot of ends.
Looks great. Any pics of the 6.0? Great looking project.
4 Attachment(s)
:wop:
right on man! going to be sweet. looks like the motor was taken out clean. no hacked wires or hoses i can see. :metal:
Hey glad to see you're getting started on it. Looking forward to updates.
You know, if the turbo 400 that was in there is good you can just use a crank spacer and run the turbo 400 since you dont have a trans yet. Just an option.
Great looking project! I can totally relate to the cracked block. All you need is a little JB weld....it will fix you right up. Sweet looking new engine too! subscribed.
nice.. good luck with build
So I've been trying to get undo the cab mounts so that I can clean up the frame and install new body mounts but I can't get the bolts out.
An impact wasn't cutting it so I put a couple small holes on the inside of the cab to get some wd40 on the nuts. That didn't work. Anybody have a similar situation? If so how did you go about getting them out? I considered cutting the head of the bolt off so i can just start on the frame, but that still leaves me with a bolt stuck in the cab. Any suggestions? |
Doing the same swap, subscribed.
instead of wd40 you should try some pb blaster or better yet Kryoil.
They are some of the best penitrating oils i have found. With kryoil beinghte best but less commonly avaiable. You may want to soak it and let it work for a day. |
1/2" or 3/4 brake over bar with a cheater pipe should do it that how I got mine off
I 2nd the cheater pipe... do it do it do it
nice build thread man that swap is exactly what i have been wanting to do.. this is the guy who sold you the plastic trim pieces.. ill let you know on back window..
