My 68 C10 Blowen LS2
5 Attachment(s)
I'm new to this forum so i thought i would share pics of my ride.
Re: My 68 C10 Blowen LS2
very nice and welcome!!!!!!
what radiator and fans did u order?
Nice truck! Looks like fun!!!
Very nice! Got any more pics?
Welcome to the forum 68 c10 ls2. Thanks for sharing the pics of that LWB blown and bad beauty.
I have a BE COOL radiator and a universal twin fan set up from JEGS ran with a SPAL twin fan controler. This step up works AWSOME!
I like! Welcome to the board.
LS power, Nice!
Dag-gum! I'll be that thing gets up to 45mph purdy dang quick. :lol:
Nice truck! |
I think we need to know more about whats under the hood =)
WELCOME!!! and nice ride
It a stock 02 6.0L with a 02 MAG 112 chager, running 60lb injectors, 4L80E trans, stock 12bolt rear end with 3.73 gears and a limited slip unit. Best time at the track was a 13.60 at 98mph (i had to baby it out of the hole beacause other wise it just spins)
Awesome looking truck! Where did you mount the battery? Looks like the air intake is in the normal battery location?
i put the battery on the outside right frame rail under the bed.
Very nice color - I really like the wheels and tires. Welcome to the board. Check out SactoJim's pickup - very similar color, and a really beautiful truck as well.
Nice rig... no inner fenders?
Gary |
Sweet ride man!
Mind me asking how much the Supercharger set you back $$$$? I was looking at a similar Kenny Bell SC and it was running around $5K to $6K depending on the goodies you got with it. I have thought about doing the same thing to my 04 2500HD. Im sure your truck has got to be pushing close to 500 ponies with that set up. You have one great looking truck and I have thought about putting a 6 Liter in my 67 ShortWide I am building now. I recently found a person who can get a completely new 6 liter, 4l80 tranny, radiator, wiring ECU the whole wiring harness for $3600. Its real tempting. Thanks for any info you can give me on this. One other question, Was the Tranny a pain to install (Crossmembers and just the physical size of the tranny)?
Thanks, JRBECK64 |
I got the blower from a friend that he had found so the blower was $1900, new injectors $360 and a mustag intercooler $150. The way it sits right now its about 425hp. This spring it getting new 243 heads, new cam, and a new style MAG 112 that will push about 12psi (instead of the 8psi i got now). I will be running E85, i figure it will be about 625hp with the new setup. The tranny was easy. Once the motor and trans was sitting in the truck all i had to do was move the trans crossmember backwards a drill new bolt holes in the frame.
That just aent right man :smoke:
Dam thats sweet truck and motor setup!!! |
Again that is one sweet truck. JRBECK64 |
Nice setup, I'm doing a similar one myself in my 69 burb. Did you do your tune yourself or take it to a shop? What fuel pump and pressure regulator did you use?
Sharp.......
Smitty |
