Bought another toy today
I bought me a 2 owner (prior to the current owner who is jacking the m&t) '75 2wd 1/2 ton Burb today. It needs some paint work, but other than the passenger front door, it doesn't have any major cancer. It has manual windows, but they all work and the doors open & shut very well. No signs of rusty floor pans anywhere. And the rear hatch opens and shuts without issue, and has a power window :). The guy bought it for the motor & trans (454 & th400), but I drove it to verify how well it drives. I'll be picking it up this weekend. Btw...The a/c blows cold :metal:, it has rear a/c, but it isn't hooked up, but i'll look into that when I get it home.
It will need a motor and trans, new weatherstripping throughout and of course paint and body work. I'm going to leave it pretty stock, besides the paint colors, it will be a darker blue w/ a silver or Lt. grey in place of the white. I'll put the 15x8" A/R Aluminum bullet holes w/ the 31x10.50r15 E load range tires off of my '76 Blazer, and use this jewel to tug my "new" 32' Travel trailer to the beach. Gonna try it with the crate 350 and th350 that is in the '76 Blazer to start. |
Re: Bought another toy today
Here's the W&T combo that I'll put on it.
It won't be really "cool" looking, but it will be very functional and way better looking than it is now. |
Man that looks real nice, I saw your ad for the blazer on craigs not to long ago. Was just searching while I was in school, did you decide not to sell it?
Yeah, I decided to keep it. I've collected a bunch of parts for it, but I need something to tow with, so this will get the nod.
Nice bro! sounds like a good plan!
if your loosing the ground effects hit me up im very interested in them
Thats cool! I just about got one last year, but Like I need something more..:lol:
Oh, I don't "need" this one, but my rational for it is that I have this 32' Travel Trailer and I think a clean, functional ole square would be a cool hauler. I really wish it had been a 3/4 Ton, but it has like 138 leafs in the rear so I think it will be able to handle it without issue :lol:
I won't get it home until this weekend, but I will surely let you know.
Well the '75 Burb fell through. They had problems getting the motor out and managed to cut up the harness, break the windshield, and bend the crap out of the DS A pillar.
But, I did end up buying a kinda running driving '88 Burb yesterday for next to NOTHING. I actually did drive it home, but also found out that the transmission is on its very last legs, the motor smokes like a tar kettle, and it may have a few electrical gremlins. But I was planning on putting a 6.0L and a 4L80E into the '75, so this one should be an even better candidate. I'll post up some pics once I get the 22" wire wheels off it and the stickers that are all over it off :barf: But it already has a flip kit w/ a notch and one drop spindle on the left front :lol:, but I have some parts I can throw at it to make it much better ;) |
Lol, one drop spindle? Where's the other one?
It took me 5 hours to get the 22" Knock off wires off the truck. When the PO put the wheels on, he didn't put any anti-seize on the threads, so they were corroded and DID NOT want to come off. I got 3 of them off in the typical fashion, but the right front took some thought. I ended up cutting the knock off "spinner", which looks like a 4" 10 sided nut, with the plasma cutter and pulling the rotor off the truck with the wheel. What a PITA, but they are off. I also went ahead and pulled the rearend out from under it, so I can fit the McGaughy rear big brake kit and the Auburn Diff and new gears/bearings because this rearend was certainly questionable after seeing the front suspension. I'm glad I did, because the spider gears in the diff. were razor sharp :metal:. The flip kit was backwards, as in the bracket hole was facing rearward rather than forward, but the notch is in the right place. It also has a really cool shock relocation spring pad addition rather than bolting to the stock axle shock mount. That is probably my favorite part so far. I'm thinking that since I have already started fabbing up the c-notch and flip bracket and u-bolt/spring pad, I will add this feature to mine ;). I have most of the parts to lower the front end, but I am going to go ahead and replace all of the steering pieces/parts (i.e. Ball Joints, tierod ends, etc.) so I know there safe. Now for a pic :lol: |
3 Attachment(s)
Here it is this morning. Poor thing, but I have great plans for it.
I'm thinkin' 6.0L/4L80e swap, raised up in the rear just a couple of inches, lowering the front properly ;), and a Round Eye front end. This way I get the Round Eye 'Burb that I really want with the modern drivetrain and the interior advantages of the '88. I added the pic of the guages just to say I paid less for the whole truck then I would have paid for the 6 guages :metal: |
Nice score. Looks like you could recoup your purchase price by selling the rims too...
crazy what some people will do to lower one...looks sad sitting there...LOL. Thats why I was so happy to find mine in stock trim for 500.00
It looks soooo much better sitting on the ground, shoes off, busted grill out. Like it's just waiting for someone to pick it up and dust it off.
There's hope for that one now. |
Do you still have access to the rest of the '75? If so, snatch the 12 bolt rear out, too. It is a near direct bolt in to the '88.
It's already had a 12 bolt under it. It is stamped GM84, so I assume it came out of an '84 model. I have it out from under it to install a new 3.42 ring & pinion, Auburn posi, & the McGaughy 13" rear big brake kit. Axles are at the machine shop getting the axle flange and hub turned down to fit the C5 rotor ;).
:metal:
Damn Ed..............................You are finding all of the good toys in BAMA!!!!!!!!! Maybe I need to make a road trip....................
^^^Come on!!! You have an open invitation :metal:
