Classic Air Cleaner for LSx Motor
5 Attachment(s)
I wanted a more classic look for my air cleaner than the typical cone filters. My swap is a 2005 6.0 LS2 into my 65 fleet. So I built a plenum and used a standard 14" round air cleaner on top of it.
This is my first aluminum welding project so I tried to make it as easy to weld as I could. Seems to work well, the truck is back on the road now. TR |
Re: Classic Air Cleaner for LSx Motor
looks cool so far
5 Attachment(s)
More Pics.
4 Attachment(s)
Last Pics.
awesome......great job
2 Attachment(s)
Oh, I forgot to mention that you need a filtered, measured, air line to feed the crankcase positive ventilation system. I added a fitting to the tube along the front of the induction. I safety wired the nut since if it came loose the result would not be good.
Thanks for the comment loC10. Tr |
Fantastic job! I love creative fab work. I'm a fan!
Man that thing is cool! Great how to also. What did you weld it with? I've got a miller spool gun but it's a POS & I just cant get it dialed in. Ive been pestering the boss for a tig but the shops just to slow right now.
Thanks Mac! I used a water cooled TIG torch running on a very old Miller Dialarc 250. TR |
I need something like that before I build my fuel tank.May just have to break down & buy one myself!
2 Attachment(s)
I forgot I had these pics. This is the actual standoffs and mounting plate I used to gain hood clearance.
I also had to move the air cleaner further forward using this mounting plate in order to miss the rear hood cross member. I used that fitting on the fuel rail to connect the fuel pressure gage you see in the finished pictures. It is nice to be able to see the actual fuel pressure when de-bugging. There is no fuel pressure sensor on these engines. My only problem starting the engine was not having sense enough to purge the air out of the fuel rail using the schrader valve on the rail. TR |
