Blazer rear seat mounting
I recently bought a nice rear seat from a fella off ck5.com and after setting it in the rear of the '70 I notice the brackets dont line up with the rear mount holes..is there any difference between the years of seats 69-72?..does anyone have a pic of the rear mount holes with seat removed or installed that I could compare to mine?
Any help is appreciated... ------------------ <A HREF="http://communities.msn.com/OurMudToys I" TARGET=_blank>http://communities.msn.com/OurMudToys </A> Check out my '70K5Blazer 350/205 (project 35"BOGGERS)4"suspension/3"body installed,starting bodywork&paint 86K5BLAZER 454ci.350/205 case 4" susp.,3"body 3/4ton4.10s 38"Swamper sx 83CJ-7 304ci.edelbrock 600 and performer intake ,headers 31"Swamper sx '86 GMC plowtruck (BOSS V-PLOW) "Welcome to where time stands still No one leaves and no one will Moon is full,never seems to change Just labeled MENTALLY DERANGED..." "THE INTIMIDATOR" gone but never forgotten !!! |
ttt
I just responded to your post on CK5. I have a '69 without a seat. I could measure the distance in the brackets in the bed if it will help you but I would assume that my brackets are the same as yours since there's only a year difference.
------------------ '69 K-5 Blazer - 350/TH350, 6" lift, 35" tires Bothell, WA |
bouncytruck...I just went out and measured mine and started at drivers side wheel well looking at dash they go 4",19",27&1/2"& 46"..the two outer brackets line up but two inner are off..the third 46" marked hole is way off being closer towards the left 19" hole.....would you mind terribly measuring yours for me?..
I'll measure them tonight when I get home and post them tomorrow.
