99 lq4???
looking at a 6.0L and 4l80e in a 99 work truck, are they a standard lq4, seeing as they were the first one out is there any issues with them. I heard that some had cast heads, and this ones on a tender and I cant see it to verify should I pass and watch for a newer engine???
thanks bark |
Re: 99 lq4???
Re: 99 lq4???
well that sucks, you say the crank is longer and will only work with a 4l80e?? what do they do with the newer 6.0's do they use a spacer, cause I've read that you can get them with 4l60e in some suv
also can a guy bolt on aluminum heads off of a newer 6.0??? |
Re: 99 lq4???
