put panosonic deck in 85...yellow and red tied together??
brother in law put radio in for me...
tied red and yellow together. i have a wire running from wires for radio to fuse box. as was there before i got the truck, harness with wires attached and then a yellow running to fuse box. problem is, no memory. so im thinking the yellow would be the constant that would keep memory. if im wrong...well then im wrong. but i knwo the radio works fine. just no memory. got the floating yellow going into the radio fuse. should i change where the yellow goes into fuse box or do i have to seperate the red and yellow and then....???? thanks for any help. |
Re: put panosonic deck in 85...yellow and red tied together??
Red and yellow should be seperate... I can't remember which is which, but I'm inclined to say that yellow is contant.
red goes to an ignition switched power and yellow goes to a battery constant powersource both can be found in the fuse block generally and a male spade connector will work wonders for you
^^^What he said...
