07 Avalanche, Aluminum Lower A Control arms to Steel arms?
Anyone know the compatability of the newer GM trucks and lower control arms?
I have a 07 Avalanche with bad lower ball joints, which requires a complete new lower control arm to get the new ball joint Do the 08 and up chevy 4x4's has cast or aluminum lower A Arms? I was wondering if i could swap them out for a set of cast iron Lower arms, or some sort of lower control arm with a replacable ball joint. maybe aftermarket??? the Avalanche has struts and coil springs. thanks if you have done this before |
Re: 07 Avalanche, Aluminum Lower A Control arms to Steel arms?
Do your originals have grease fittings? Usually the Moog replacements will have a grease fitting which will greatly extend the life. I was looking at Oreilly's site and they list an aluminum and a steel lower arm.
no grease zerk,
ill check out the Orelliy site |
well Orelliy offers ball joints for both iron and steel arms, they list an arm but cant get the arm from a store. WTF
I cant believe nobody has been through this before.
Im gonna remove the alum arm and see whats the difference from that to steel |
for anyones info, the steel arms are cheaper than the aluminum arms and they are direct fit into anything with an aluminum arm
