Edelbrock 90mm Throttle Bodies
http://www.edelbrock.com/automotive_...mages/3864.jpg
VICTOR LS SERIES 90MM RACING THROTTLE BODY VICTOR RACING THROTTLE BODIES & ADAPTERS Based on our 80mm LS1 throttle body #3867, the Victor LS series 90mm racing throttle body is designed to increase flow and horsepower potential in competition applications. The lower water tube has been removed, but it retains the stock LS1 style TPS, IAC and PCV port. Extra idle control is provided with the addition of an idle bleed screw. It has both an LS1 and LS2 intake manifold flange and can be mounted on aftermarket LS1 manifolds with a 90mm opening, or LS2 and LS7 factory manifolds, but does not retain all stock equipment or throttle cable setup. It is perfect for enthusiasts who want to use an LS2 or LS7 manifold or entire engine in an older vehicle with no fly-by-wire throttle. 90mm Throttle Body (includes TPS/IAC) 3864 $345 shipped 90mm Throttle Body (without TPS/IAC) 38640 $265 shipped If interested contact me about payment options. Once I have these loaded on the website I will post link to them. |
