Scratch Marks In Windshield
How do you buff them out. Start out with rubbing compound? Never done it before,please help.
Re: Scratch Marks In Windshield
you can use "BONAMI" that you can get in most grocery stores..and make it a paste...Use a terry cloth make a paste..and buff it out,
If they are deeper scratches..Eastwood sells "Rhodite" that will really clean up the whole thing good. |
besst for deeper scratching and pitting is to replace windshield
alot of the home repairs leave visual distortion anduneven glass surface making wipers ineffective |
Were you kidding about household cleanser? It looks like something off the wipers scratched it. a new windshield isnt an option i got one of those headlight cleaning kits. i wasnt sure on how agressive i could go without making matters worse
The 1955 chevy's with a 265 V8 used oil ,bypassing the rings..when they were new..Chevy's fix was runs motor around 2,000 rpm...pour a teaspoon of bonami down the carb...3 times...And it would reseal the rings to stop it from burning oil...Yes good stuff.. worked on an old 76 ford 390 that smoked bad...I used quite a bit of it...fixed it..And the truck left here..don't use oil now.. |
There are windshield buffing products out there. Most of them are a cream base and use a foam buffer. I have never tried it and when I looked at it, the cost of a new windshield was worth the effort vice using up all of my time. I found a lot of other things to do instead of trying to buff the windshield and then be POd at the finish on it, when the weather got cold and I had to use the wipers.
yep winshields are so readily available new and cheap makes no sence to spend time on something that can affect vision when needed most
is bon ami same as ajax or comet or dutch cleanser?
glass is like new |
