Put TH400 back in, won't shift
Well, I've been creating several threads with different issues of my friends' '63 C10. It started with putting a new engine in (which is running great now, woohoo). When attaching the transmission he broke the pump, which he replaced and now the car moves, but: It won't shift out of first gear! My friend has an idea that the solenoid on the transmission for the electric kick-down might be causing it, but I haven't a clue. Can you pros help?
Thanks! |
Re: Put TH400 back in, won't shift
do you have the vacumn line hooked up to the modulator?
Yessir, he reports his vaccum is plugged in correctly to the intake manifold, and there is a good suction. I suspected this myself as possibly being a problem. Maybe his modulator is bad?
Okay I will let him know. Replacing the modulator is cheap anyway and wouldn't hurt.
If the modulator doesn't do it, you could look at the governor next. The symptoms are about right, but I have no clue how there could be any connection with a damaged pump. A more likely possibility might be that a small piece of debris from the pump somehow got into the valve body.
Ray |
