54' 3100 restore...my current project
This is my friends truck that I'm restoring for him. Started this weekend and got pretty far into it. This is my insentive to get my truck done next...so whatch for that build.
Got the bed off, sanded down, almost ready for primer. Engine and trans pulled. Gas tank behind the seat pulled. Whats going in: MII front suspension with rack and pinion. Fuel cell. Will be dropped on static, not air. truck is being built as a clean cruiser...gonna be shweet. I will be updating this weekly or as more work is done. http://img.photobucket.com/albums/v2...3-21-10001.jpg http://img.photobucket.com/albums/v2...3-21-10002.jpg http://img.photobucket.com/albums/v2...3-21-10005.jpg http://img.photobucket.com/albums/v2...3-21-10006.jpg http://img.photobucket.com/albums/v2...3-21-10007.jpg http://img.photobucket.com/albums/v2...3-21-10009.jpg http://img.photobucket.com/albums/v2...3-21-10010.jpg |
Re: 54' 3100 restore...my current project
http://img.photobucket.com/albums/v2...y252010013.jpg
http://img.photobucket.com/albums/v2...y252010012.jpg http://img.photobucket.com/albums/v2...y252010008.jpg http://img.photobucket.com/albums/v2...y/IMG_1482.jpg http://img.photobucket.com/albums/v2...y/IMG_1481.jpg http://img.photobucket.com/albums/v2...y/IMG_1480.jpg http://img.photobucket.com/albums/v2...y/IMG_1479.jpg |
http://img.photobucket.com/albums/v2...y/IMG_3010.jpg
http://img.photobucket.com/albums/v2...y/IMG_3009.jpg http://img.photobucket.com/albums/v2...y/IMG_3008.jpg http://img.photobucket.com/albums/v2...y/IMG_3007.jpg http://img.photobucket.com/albums/v2...y/IMG_3006.jpg http://img.photobucket.com/albums/v2...y/IMG_3005.jpg |
Engine
98' vortech block and heads. 10:1 http://img.photobucket.com/albums/v2...y/IMG_3002.jpg http://img.photobucket.com/albums/v2...y/IMG_3001.jpg http://img.photobucket.com/albums/v2...y/IMG_3000.jpg http://img.photobucket.com/albums/v2...y/IMG_2999.jpg http://img.photobucket.com/albums/v2...y/IMG_2834.jpg http://img.photobucket.com/albums/v2...y/IMG_2831.jpg http://img.photobucket.com/albums/v2...y/IMG_2829.jpg http://img.photobucket.com/albums/v2...y/IMG_3003.jpg |
Put the engine/ trans and front shocks in tonight
http://img.photobucket.com/albums/v2...y/IMG_3013.jpg http://img.photobucket.com/albums/v2...y/IMG_3014.jpg http://img.photobucket.com/albums/v2...y/IMG_3015.jpg http://img.photobucket.com/albums/v2...y/IMG_3016.jpg http://img.photobucket.com/albums/v2...y/IMG_3017.jpg http://img.photobucket.com/albums/v2...y/IMG_3018.jpg |
I also have the headers ordered...coated
http://www.sandersonheaders.com/images/D/CC2_600.jpg The CC2 header is only 4" tall. For very tight clearance connections this header provides excellent clearance. fits all GM straight and angle plug heads, plus Dart, Trick Flow, Brodix, Brownfield, and Edelbrock cylinder heads. Comes with all hardware necessary for installation. SPECIFICATIONS: Engine : Small Block Chevy 265-400 Primary Tube Diameter : 1½" Collector Diameter : 2½" Weight : 14 LBS / 6.35 KGS FEATURES: 16-Gauge Primary and Collector Tube Thickness 3/8" Thick Flange Patented Flange Design Requires NO Gaskets Tightest Fitting Header Available Anywhere! Made in the USA INCLUDES: Header Bolt Set OPTIONS: Our Aluminized Ceramic Coating is available and RECOMMENDED on all Sanderson Headers. We apply a multi-layer inside and outside silver ceramic coating in-house to meet our high standards of quality, and polish the coated header to a high luster. This coating provides aerospace and military technology to your vehicle to control the heat in your engine bay, improve cylinder scavenging of exhaust gases, and increase the longevity of your header investment. (read more here) You can select Thermal Ceramic Coating below, and the header price and part number will be automatically updated. Copper Collector Gaskets are recommended for all Sanderson headers (SEE RELATED PRODUCTS BELOW) Sanderson Headers do not include collector bolts due to our customers' wide range of preference. We do offer a collector bolt set that features Grade 8 Bolts with Locking Nuts (SEE RELATED PRODUCTS BELOW) NOTES: This header offers 1½" primary tubes, which is good for about 350HP on a casually used 350 cubic inch or smaller engine application. For larger or higher horsepower applications we offer this header with 1-5/8" primary tube sizes, Order #CC2_158. Will fit Mustang and Vega style steering as long as there is 2" of clearance between the center exhaust ports and the steering gear. The Patented Leak-Free Design that Sanderson Headers offer you is the only leak-free flange design on the market ... Do Not Attempt To Use Flange Gaskets! The raised flange on the Sanderson Headers will buckle the gasket during tightening and actually cause a leak! Sanderson Headers are NOT emissions legal on pollution-controlled motor vehicles. It is the purchaser's responsibility to verify local regulations for compliance. Wrapping your Sanderson Headers with ANY thermal tape voids your header warranty. The best thermal protection for your headers is our Aluminized Ceramic Coating that is available for every Sanderson Header. WARRANTY: Limited 5-Year Warranty (read more here) DIMENSIONS: (Right and Left Side Headers are the Same) Tube Size ............ 1½" Collector Size ....... 2½" DIM A ................. 2¾" DIM B ................. 4" Weight (Lbs / Kg) . 14 / 6.35 |
got a little more work done today. radiator support and radi are in. mock up of inner fenders and supports. got a bunch of sanding done on the cab, i'll get pics of that tomorrow
http://img.photobucket.com/albums/v2...y/IMG_3029.jpg http://img.photobucket.com/albums/v2...y/IMG_3028.jpg http://img.photobucket.com/albums/v2...y/IMG_3027.jpg http://img.photobucket.com/albums/v2...y/IMG_3026.jpg http://img.photobucket.com/albums/v2...y/IMG_3030.jpg |
very nice.... gotta nice clean look to it.
some body work getting done
http://img.photobucket.com/albums/v2...y/IMG_3050.jpg http://img.photobucket.com/albums/v2...y/IMG_3049.jpg http://img.photobucket.com/albums/v2...y/IMG_3048.jpg http://img.photobucket.com/albums/v2...y/IMG_3047.jpg http://img.photobucket.com/albums/v2...y/IMG_3046.jpg http://img.photobucket.com/albums/v2...y/IMG_3045.jpg http://img.photobucket.com/albums/v2...y/IMG_3044.jpg |
droppedgmc, Very nice build. Not too many 54-55 on here.
Nice build, keep up the good work.
Hey neighbor looks like you getting some progress done,should be a sweet ride when your done.I use to live over in Roggen
Looking good.
Impressive work!
nice!!!! :metal:
Doors
http://img.photobucket.com/albums/v2...y/IMG_3118.jpg http://img.photobucket.com/albums/v2...y/IMG_3117.jpg Tail lights. Going to be LED cadi's http://img.photobucket.com/albums/v2...y/IMG_3123.jpg http://img.photobucket.com/albums/v2...y/IMG_3124.jpg http://img.photobucket.com/albums/v2...y/IMG_3125.jpg |
more light work. shaving the stake pockets
http://img.photobucket.com/albums/v2...y/IMG_3139.jpg http://img.photobucket.com/albums/v2...y/IMG_3138.jpg http://img.photobucket.com/albums/v2...y/IMG_3137.jpg http://img.photobucket.com/albums/v2...y/IMG_3136.jpg http://img.photobucket.com/albums/v2...y/IMG_3135.jpg http://img.photobucket.com/albums/v2...y/IMG_3134.jpg |
The tail lights look slick
Love it!
at that pace it will be finished in no time. nice work
Rear Tails almost complete
http://img.photobucket.com/albums/v2...y/3-24-116.jpg http://img.photobucket.com/albums/v2...y/3-24-115.jpg Paint http://img.photobucket.com/albums/v2...y/3-24-114.jpg http://img.photobucket.com/albums/v2...y/3-24-113.jpg Exhaust down pipe from header http://img.photobucket.com/albums/v2...y/3-24-112.jpg http://img.photobucket.com/albums/v2...y/3-24-111.jpg |
this build is flying along! Looks great!
