Lots of assorted left over parts for sale in SoCal
5 Attachment(s)
I have several parts that are left over from my build. Let me know if you would like more/better pictures of anything.
1. Brake booster/master cyl/prop valve assy. This worked perfectly when removed about a week ago. The only thing I know is wrong is the fire wall seal is worn. I am asking $75 plus actual shipping. SOLD 2. Factory 1967 bench seat covered in a brand new red/black hounds-tooth cover. The cover is in perfect condition, but the foam underneath is original, so it is kinda' soft. I haven't had the cover off, so I don't know what the frame is like, but it is sturdy and usable. I am asking $200 plus actual shipping, although I would prefer pick-up, since it is so big. 3. Factory AC control unit. All levers work / switch worked when removed. The cables are still attached and seem decent. I am asking $75 plus actual shipping. SOLD 4. Factory stereo. I have no idea if it works and I have no interest in testing it. I am asking $25 plus shipping. SOLD 5. Full set of mechanical Equus gauges. The speedo and tach are 3 3/8" and the water temp, fuel level, oil pressure, and volts are all 2 1/16". They all functioned perfectly and includes the senders. There are no scratches or defects. The only issue is that the tach retaining ring is missing. These are sold at any Kragen/O'reilly, so if you have an issue then just buy a replacement there and put the part that is giving you problems in the package and return it. I am asking $200 plus shipping. All prices are negotiable, so make an offer. |
Re: Lots of assorted left over parts for sale in SoCal
I also have a bunch of factory AC/heater parts and a factory radiator fan shroud. Let me know what you are looking for and I can take pics.
That booster setup work on a 68 3/4 ton 2wd c20??
my dad has a 70 and wants to get an original radio to stick in the hole on the dash as he says ,and then wants to get a cheapo one from wal mart to stick under the seat and he found one with bad chrome for .99 beleive it or not but it is too far to ship ,he will never use this radio but he will just install it so what is the lowest on the radio that you can go?
Maybe someone will chime in but if not thats ok.
This is new to me so I'm not sure either. I got 4 bolts spaced approx. 4" apart but I'm not sure about the other one you mention. Just wondering if they are different setups for 1/2 & 3/4. |
If you have the knobs for the radio I will take it.
Kevin |
ttt. Nobody needs any of these parts. They seem like very reasonable prices to me. I also have a blazer gas tank SOLD, OEM trans X-member, stock height coil springs (front and back), OEM pan-hard bar, and front disc brake setup (spindles, calipers, rotors, etc).
What would the shipping be on the mc to fort worth, tx 76112? and do you still have the radio?
I will take the fan shrould for $40 and I will pick it up? please PM if you are a go with pick up info.
Thanks, CORSAIR |
Tell me about the Blazer tank may be interested in it along with shroud?
Can I get more info on the front disc brake setup?
Thanks. |
3 Attachment(s)
Here are some pics of the brakes, gas tank, and trans X-member.
The other caliper is there. I just took it off the spindle.
How much for the mc assembly shipped to 95822 (Sac, CA)? I take it the prop valve is for a disc/drum set up?
interested in booster, brakes, and cross member if they get to me...
