Shock Mounting(help)
I WOULD LIKE TO KNOW WHAT THE BEST AND EASIEST WAY TO FIX A REAR SHOCK MOUNTING BRACKET THAT IS UP ON THE FRAME MINE IS RUSTING THROUGH AND I WONDERED IF MAYBE THEY SOLD A REPLACEMENT THANKS ANY ADVICE IS APPRECIATED.:D
I had a broken one that I had rewelded but a rusted one? not good. I don't think that they are available aftermarket or otherwise. You will probably need a used donor. Try posting in parts. Someone may be able to help. Good Luck
