Best way to raise the bed floor
Alright guys, It's time to at least start thinking about the next phase of the truck, and that will be raising the bed floor. I'm not sure how to do it really. My original thought was to leave the stock crossmembers in, and space it up with 3"x1" x1/16 wall square tubing, but I really don't like that idea now too much. My major concerns are strength and form. The body work on my outer skins is already done so I hope I don't have to weld on those or atleast keep it to a minimum.
Here are my goals: *I would like to run stock wheel tubs. *I would like to do a flat floor, and have the inner bedsides run straight down on the inside. I know I will have to make a skeleton out of 1x1 but I'm just not sure what to attatch it to on the outside peremeter??? *I'm not sure exactly how high I want to raise it, but I was thinking 3". I would still have to run a separate raised "notch cover" if this was the case. I cannot, for the life of me, figure out what to do for a fuel tank. I cant put it where the factory saddle bombs go cause thats where my air tanks are, my exhaust runs all the way out the back so theres no room where a blazer tank would go, and I really would like to conceal it somewhere rather than mount it to the inside of the bed. Any ideas on this?? any pictures, ideas on fuel cells/tanks, and ideas on how to attatch this new floor to the existing skins would be great. Right now the bed is assembled but all the floor/inner fenders have been cut out. The factory crossmembers are still in place. |
Re: Best way to raise the bed floor
ive been thinking about this too. i think for a gas tak you are probably going to have to modify your exhaust and do a blazer tank or a fuel cell. check out this link on the raised bed floor
http://67-72chevytrucks.com/vboard/s...d.php?t=409466 |
That is just not an option.
Posted via Mobile Device |
I just don't consider that a safe place to mount a gas tank on a bagged truck. Too close to the ground and too much danger of something puncturing it or even dragging it. Maybe I can have one made that fits between the frame rails in the front of the bed, under the raised bed floor? To me that's the safest place to put it.
Hers what my bed looks like now....
http://67-72chevytrucks.com/vboard/p...pictureid=5071 Posted via Mobile Device |
put it between the rails, in the front part of your bed. Just build it to have clearence for the driveshaft. I think that's my plans on my 64'.
Post your frame pics from the rear again. That will give us an idea of what your working with. Take a look at what Keith (n2billet) is doing on Hazel.
these are the only ones I have handy. http://67-72chevytrucks.com/vboard/p...pictureid=5074 http://67-72chevytrucks.com/vboard/p...pictureid=5073 |
2 Attachment(s)
My tank doesnt hang down under my frame at all
3 Attachment(s)
heres a couple shots of my bed mounts and sides
thanks for the pics that looks really nice. I found another pic...
2 Attachment(s)
now i see your exhaust dilema, how about hanging a round gas tank like my air tank
My tank is going to be in the rear but raised up quite a bit. I like the look of a raised bed floor with no notch. looks cleaner to me
Im gonna do mine like 9 and 3/4 inches. There wont be much floor left but it will hide every thing and still be able to haul some chairs and a cooler
If/when it needs to be raised so much it's extremely shallow, I prefer moderate raising & adding a stepped portion above the rear housing. This is how the floor is for my RetroRod (moderately raised & stepped over the rearend). It's one piece though w/continuous 'runners' front to rear. The main floor is 3" higher than stock & the area over the rearend is an additional 4". Would you consider slightly revising your exhaust if it ultimately exited in the same fashion? If so, what about running the pipes straight back parallel to the rails until it gets to that rear-most x-member. At that point 90° turns toward the center of the truck & into the tips? That should allow room for a fuel cell that fits under a raised floor. |
4 Attachment(s)
heres some pictures I've saved over the years that might give you some ideas.
3 Attachment(s)
couple more
