Suspension Questions
I have a thread started in the 67-72 section but have a few questions regarding the 88-98 trucks.
http://67-72chevytrucks.com/vboard/s...d.php?t=449977 Can I swap 1 ton spindles and brakes onto a 1/2 or 3/4 ton frame? Or am I better off buying a 3/4 or 1 ton frame to begin with? Thanks Guys -Nathan |
Re: Suspension Questions
Not sure about spindle swapping, but you can put HD 3/4ton/ LD 1ton [8700gvw] brake calipers on 1/2ton/LD 3/4ton rotors/spindles.
Ya i went from 1 ton to half ton so its possible to go the other way too.
http://www.duallyscene.com/forums/pr...ion-t4904.html |
Thanks Guys, just what i was looking for, just wish he showed what all he had to swap from the donor truck, And that truck is pretty to boot.
http://www.duallyscene.com/forums/su...lly-t4564.html |
