Shaving Rain Gutters/Drip Rails
5 Attachment(s)
I Know I have seen quit a few people asking how to Shave the Rain Gutters/Drip Rails.
So I figured while I do mine I will take Pictures and give more info on how I am going to go about doing this. Hope this info does go to good use for someone. First of all You will need these Required Tools: Safety Glasses Welder Grinder Grinding Sandpaper Wheel Sheet Metal Sheet Metal Cutters Always nice to have a Magnet Sawzall or Angle Die Grinder with Cutting Wheel Or use a Cutting Wheel on your Angle Grinder. Attachment 708574 Attachment 708575 Attachment 708576 Attachment 708577 Attachment 708578 Step #1. If You have your Windshield and Rubber Seal still in your Truck you should Protect it/Cover it before starting this project Unless your replacing them like I am before this truck is finished. |
Re: Shaving Rain Gutters/Drip Rails
5 Attachment(s)
Step #2
Cut the Rain Gutter/Drip Rail from the top down around an Inch in Length at a Time. Cutting to much can cause the roof to flex and move out of its original place. Be careful not to cut to close to the roof till you get a visual of what your working with and how you want it to look. some people have different tastes how they wish theirs to look so mine may not be the look you desire. Attachment 708579 Step #3 After Cutting the Rain Gutter/Drip Rail off take your grinder with your Grinding Sandpaper Wheel (Disc) if needing to grind alot of the rail still off to get closer to the roof and grind away till your happy. Attachment 708580 Step #4 Cut some Small pieces of Sheet metal to fit in the bare area where needed (Good Place to use your Magnet to hold the small Sheet Metal Pieces in Place) and Tack weld them in. Other Helpful Tips and Info in Step #5 Notice the Big Gap with no Sheet Metal in the Picture - This is where you will Add Sheet Metal If going the way I am with my Shaved style Attachment 708581 Step #5 Weld each side of where you have cut off the Rain Gutter/Drip Rail to keep it secure and not allow the roof to move or flex at all. Remember do not weld to much in one area. you want to just tack weld it up (one touch at a time in each spot) if you heat the metal up to much you will warp the sheet metal. each time you Tack weld it move to the next spot far enough away. Knowing when to quit and take a break inbetween is a good thing. (See Picture 1) Step #6 Sand down the welds smoothly with your Grinding Sandpaper Wheel(Disc). Do not use a Hard Grinding Disc also Do not sand to much of the Sheet Metal. Dont allow the Sheet Metal to turn Blue. That is what Causes it to Warp Attachment 708582 Attachment 708583 |
Here is the Passenger Side View of the Drip Rail with Primer
Attachment 708584 |
