How do I tell if I have drop spindles?
I'm trying to determine if PO put spindles on, how can I tell? I can't take the wheel off because it's on bags and my tanks aren't on ATM and my jack won't go low enough to lift it up. I did measure and with 225/70/15, the middle of the wheel bearing is at 14". Trying to order some stuff but don't want to order those if I already have them. Can anyone measure for me?
Posted via Mobile Device |
Re: How do I tell if I have drop spindles?
Can you cut the wheels enough to look at the back side. Take a pic and let us look. If the axle spud is noticeably off center then its a drop spindle.
actually, a drop spindle will have the spud closer to the center whereas a stock spindle will have the spud towards the bottom of the spindle casting ...
drop spindle ... http://67-72chevytrucks.com/gallery/...d_88_98_ch.jpg stock spindle ... http://67-72chevytrucks.com/gallery/...93/spindle.jpg |
http://67-72chevytrucks.com/gallery/...3/P2201937.jpg
http://67-72chevytrucks.com/gallery/...3/P2201940.jpg Hope these help, thanks guys your help is very much appreciated. |
those are drop spindles
Really? How can you tell? I was pretty sure they were stock after seeing Shane pics.
2 Attachment(s)
Well damn, that saves me a few hundred buckaroos!! I'm still surprised though, it's the first thing I've wanted to do that seems to be done correctly! Well, now to decide on which 4 link! Thanks again guys.
Could any of you veryify that these are NOT drop spindles?
I'm looking for ways to go lower in the front on my bagged 81 truck, but I don't want Z it or buy a dropmember so hopefully these are NOT drop spindles. http://67-72chevytrucks.com/gallery/...3/ce9ce47d.jpg |
those are stock spindles. notice how the spindle shaft itself is just barely above the lower ball joint. Drop spindles have the shaft higher up on the spindle itself....hope that makes sense
If you look closely you can sell the Belltech logo cast into the backside of them. As to telling the difference between stock and dropped, to me, it's easier to look at the steering arm. If it's straight out, it's stock, dog leg shaped, it's a drop spindle.. Here are pictures I took of a truck I dropped last year. Stock spindle, notice the straight out steering arm... http://67-72chevytrucks.com/gallery/...rmtruck132.jpg Drop spindle, notice the dog leg downward slant of the steering arm... http://67-72chevytrucks.com/gallery/...rmtruck131.jpg |
Re: Reported Post by fishingjred73 - Forum: Suspension - Reported User: Tx Firefigh
Here's another one.
