How-to....69 Camaro tank retrofit
Just finished mounting up and installing a 69 Camaro tank on my longbed 66 C10. Stay tuned for the complete write up....it's dinner time and I made a big ole batch of homemade chili.
I will say this...it's possible to do this install without removing anything from your truck. I left my bumper and bed on and managed to get it bolted up. That said...it's a PITA. If I removed my bed floor I would have been done with this 2 days ago! If you want some progress pics check out my build thread here... http://67-72chevytrucks.com/vboard/s...d.php?t=445201 |
Re: How-to....69 Camaro tank retrofit
This is a 2 person job. I wouldn't have been able to install this tank without the help of my buddy Russ. Even still it took us several days because I stoically didn't want to remove my bed after we took his off of his 81 C10...and that involved a lot of cutting
I ordered the tank from a company called Tamaraz up in Illinois. I found them on ebay, they sell the 69 Camaro tank with sending unit and tank straps as an auction. However if you call them up they'll swap the straps for the anti-squeak kit and it'll come to $170 delivered. I'm not all that impressed with their customer service since I didn't receive a shipping confirmation like they said I would, and I had to keep calling back over the course of several days to get a hold of someone. None the less my tank arrived and in good shape...albeit an odd way of packaging it. Here's how it arrived http://i160.photobucket.com/albums/t...d/100_0307.jpg http://i160.photobucket.com/albums/t...d/100_0308.jpg http://i160.photobucket.com/albums/t...d/100_0309.jpg Here are the measurements of the tank http://i160.photobucket.com/albums/t...dimensions.png Here are the measurements of the frame http://i160.photobucket.com/albums/t...Dimensions.png As you can see the tank will not fit between the frame rails, which in this case is a good thing. If it did fit in between the frame rails the filler neck wouldn't be in the right spot. To solve the mounting issue I made a bracket/spacer out of some perforated steel tubing I got from Lowes. I believe I used 1.5" tubing and it came out perfect. You'll need two pieces of it. For the straps I used 14ga perforated steel straps, also from Lowes. You'll need 2 8ft pieces. The tubing was cut with a grinder and grinding wheel to a length of 27". However you'll want to double check all of the measurements I've listed on your frame and your tank just to be safe. Bending the straps was done by hand leaving plenty of extra on both sides just to be safe. The end result was this...I give you V1.0 http://i160.photobucket.com/albums/t...d/100_0313.jpg http://i160.photobucket.com/albums/t...d/100_0310.jpg However after a night of thinking about it I decided to change up a few things...namely where the bolts on the straps were. This is an 18 gallon tank, so full it will weight 144lbs. If the 14ga steel I used was able to be bent by hand 144lbs of fuel will do the same exact thing, and that would be BAD. So enter V1.5... http://i160.photobucket.com/albums/t...d/100_0317.jpg Then I realized that the fuel line was touching the metal strap, and that's a recipie for disaster if left as is. I also remembered that there was an extra piece of foam in the anti-squeak kit so after rummaging around through all the junk in my bed I found it and put it on.....I give you V2.0 http://i160.photobucket.com/albums/t...d/100_0320.jpg Now if you're wondering why I have the straps bent down on the filler side of the tank...it's because it made it easier to carry around. You can cut them off if you want, though they came in handy to be able to push on to get the strap where I wanted it for the bolts to go into. At this point the tank was done and just needed to be mounted up. I took measurements off of the tank and figured out where the holes needed to be drilled on the cross sills under my bed. http://i160.photobucket.com/albums/t...tlocations.png All was dandy so I tried to install the tank. But we ran into a slight problem....I couldn't get my wrench in far enough to reach where I needed the nut to go to!!! I thought for sure I was going to need to add another cross sill and have that as my front mounting point. Then the good idea fairy paid me a visit and this is what resulted...I give you v2.5 http://i160.photobucket.com/albums/t...d/100_0324.jpg I'm no engineer but that seemed like the best spot to cut an access notch into the rail. I ended up having to enlarge it from what you see there to really be about 4 holes long instead of 3....and I did that while the tank was under the truck...very sketchy, so learn from my mistake!!! I also needed to widen the notch a bit more so I could turn my wrench in there and also so I could get it out. If I were to do it all over again I'd at least remove a few boards from the bed to get better access to the bolts. After several hours of swearing, cutting myself on metal, getting dirt/rust/gunk in my eyes, and breaking a finger I got the damn thing installed. Here are the pics http://i160.photobucket.com/albums/t...d/100_0330.jpg http://i160.photobucket.com/albums/t...d/100_0334.jpg http://i160.photobucket.com/albums/t...d/100_0331.jpg http://i160.photobucket.com/albums/t...d/100_0338.jpg http://i160.photobucket.com/albums/t...d/100_0341.jpg http://i160.photobucket.com/albums/t...d/100_0343.jpg http://i160.photobucket.com/albums/t...d/100_0329.jpg I did run into a few more problems. The biggest one was I couldn't get my wrench into the rear of the brackets to tighten the nuts...and it just so happened that they were in the same damn hole. I ended up tightening the bolt going from teh cross sill to the bracket all the way, and the one from the bracket to the tank strap is as far as it will go. There's a lock washer on the tank strap bolt so I'm not to worried about it, however the two bolt stems are touching and the tank strap bolt has a bit more thread to go to be completely tightened down. The best solution to this problem would be to use another hole...but I'm gonna try this and see how it goes. It eventually got to the point where my wrench was completely useless...so I busted out my harbor freight prybar, wedged it in there against a flat side of the nut and tightened it all the way down. Be careful when you're doing this...I punched myself in the face when the pry bar slipped off. I have to still run the wires for the sending unit, put a resistor on said wire to convert the 90ohm sender to a 30ohm sender so it's compatible with my stock gauges, and run the fuel lines. Hopefully by the end of the week I'll have it all completely done. I'm waiting on a locking gas cap from Advance Auto Parts to get here. I also have to make my license plate bracket, and being the resourceful/cheap Polack/Chink that I am I'm going to try to reuse the scraps from the tank straps and brackets to make it. The flip down plate bracket is off of a 90's Caprice and locks into place when flipped down. So in conclusion...it was a learning experience...some blood was shed...a lot of choice words were said...a digit was broken....and a tank was installed. On a scale of 1 to 10 in terms of difficulty I'd give this a 4, it was mostly a PITA for me since I was trying to figure out a good bit of this on the fly but with this writeup if you choose to do this it'll be pretty easy. It's even easier if you take the dang bed off or remove a board or two from the bed. ...and don't ask about those random wires in the pictures or the chains...I didn't do it, the PO did when he did his hackjob wiring the trailer tail lights to the truck. Rewiring the whole truck is a whole nother project I'll get into after I do the rust repair in the cab. The chains are from the PO's ghetto lowering job where he chained the shocks down to compress the springs. I just removed them from the bottom to make it not hurt so bad when drove the truck. |
Oh yeah...and ground clearance since I'm sure someone will ask about it...As far as I know I'm at stock height
7" to the bottom of the pumpkin 11" to the bottom of the tank If you're dropped subtract your amount of drop from what I've listed above and it may or may not be correct. I'm not sure if my springs have been heated, how much they've sagged, or if it'll change when I replace my worn out shocks. And just in case someone missed it the tank capacity is 18 gallons. The tank comes with a 90 OHM sending unit, so you'll need to add a resistor or pot to your wiring to "convert" it to work with your stock gauges. If you've got aftermarket or are going to aftermarket gauges just get a 0-90 ohm gauge and be done with it. I'm still trying to figure out how I'm going to do the wiring and keep it waterproof. I'll be adding pics and diagrams of the wiring and running of the fuel lines. If you went to my build thread you'll see I'm working on a very limited budget with very limited resources. If you had a welder you could weld the nuts to the bracket and call it a day. If I had a welder I'd also weld on some square tubing across the bottom of the frame rails to protect the tank from a rear end collision. Mine is exposed right now, but the only way to hit it is to go under the bumper and in about a foot and change. The only tools I used were... -tape measure -sharpie -cardboard -floor jack -wrenches -ratchet and sockets -prybar Wear gloves when doing this. I sliced my hands open pretty good a few times on the edges of the tank, they're razor sharp. I also busted my knuckles a few times on the frame/tank, punched myself in the face, and broke a finger when the grinder caught and locked up crushing my finger between it and the metal. Wear eyepro while cutting, sparks will fly and they burn...so also wear long sleeves, pants, and a hat. I've got the burns on my arms to prove you should. Ear pro is also a good idea, I didn't wear any because I'm an idiot, so don't be an idiot like me, but I consciously remember at several points saying I wish I had some ear pro. ....and no animals were hurt during the install....except me....zeh plangium...kluk-e-joy-yey |
Final thought...and then I'm going to bed...maybe...
Lakeroadster's install is honestly a much cleaner install as it goes in between the frame rails and virtually drops right in...however I didn't want to cut a hole in the side of my bed/frame to run the tank. I thought about doing an in bed fill, but I couldn't find any that had the filler in the middle (I know there are some out there now though, I found them after I bought the tank), and I also didn't really want to have the filler in my bed wood. My dad gave me the idea for the rear fill tank, and upon googling the idea it had been done before http://67-72chevytrucks.com/vboard/s...d.php?t=403321 Thanks for paving the way 63GENIII. Had you not done this already I'd probably be up a rather putrid creek without a propulsion device |
Daylight pictures and a side profile shot
http://i160.photobucket.com/albums/t...d/100_0346.jpg http://i160.photobucket.com/albums/t...d/100_0345.jpg http://i160.photobucket.com/albums/t...d/100_0348.jpg http://i160.photobucket.com/albums/t...d/100_0344.jpg I also got my locking gas cap today, so I'll be trying to hook the tank up this weekend. |
