Tilt Column: Lock plate removal
I have a 91 GMC 5.7L: That has tilt steering and its lose I have removed the steering wheel now I am looking at a metal plate or sprocket. My question is how do you remove this. Does this need a gear puller to remove it.
Re: Need help w/ Tilt Collum
The “Lock Ring” holds it on. It has a spring behind it. Notice the tool being used to compress the spring so the lock ring can be removed.
http://67-72chevytrucks.com/gallery/data/1093/col6.jpg http://67-72chevytrucks.com/gallery/data/1093/col7.jpg The photos are from this site which has instructions: http://www.fieros.de/en/articles/steering.html Here is another photo of a tool made for this job: http://67-72chevytrucks.com/gallery/...column-03r.jpg |
Here are some more sites that may be helpful:
http://elcaminocentral.com/article95.html Looks like on this site he did the quick fix and did not take it apart far enough to tighten all four fasteners. http://www.chevyasylum.com/column/tiltcol.html Exploded View of a tilt column. http://www.nastyz28.com/tech/e-tiltcol.html |
