Barbwire Customs Project#1
5 Attachment(s)
We started this Project about 2 years ago and we planned to be finished a year ago. So like all projects this one is lagging behind. Here are some pics of where we started and where we are.
We are going for the shop truck/hot rod theme. These are some of the first pics. Attachment 771819 Attachment 771820 Attachment 771821 Attachment 771822 Attachment 771823 |
Re: Barbwire Customs Project#1
5 Attachment(s)
Attachment 771824
Attachment 771825 Attachment 771826 Attachment 771827 Attachment 771829 We painted the firewall white like the old hot rods used to be painted. |
Great 1st post.
You've been here since 2008? Looking forward to more pics. |
3 Attachment(s)
4 Attachment(s)
Here we are putting the cab back on the frame.
Attachment 771835 Attachment 771836 Attachment 771837 Attachment 771838 Thanks Keith. We have gotten alot of inpiration for this truck from alot of the people on this site. |
5 Attachment(s)
Here is a pic of when we were working on the rear spoiler.
Attachment 771842 A pic of what a 18" wheel might look look like with the finished product. Attachment 771843 Here is a sneek peek of the grill. Attachment 771844 Attachment 771848 Attachment 771849 |
4 Attachment(s)
The bed frame.
Attachment 771853 The bed frame. Attachment 771854 The relocated tailgate handle. Attachment 771855 The some what finished rear spoiler and what the exhaust might look like. Attachment 771858 |
4 Attachment(s)
Here are some pics of when the bed floor was being constructed.
Attachment 771861 Attachment 771862 Attachment 771863 Attachment 771864 |
4 Attachment(s)
Here are some pics of the finished exhaust.
Attachment 771866 Attachment 771867 Attachment 771868 Attachment 771869 |
5 Attachment(s)
Here are some pics of the new a arms an some pics of the motor bolted in.
Attachment 771870 Attachment 771871 Attachment 771872 Attachment 771873 Attachment 771874 |
4 Attachment(s)
Here are some pics of the cab after we painted it. We are going with a flat/satin black.
Attachment 771877 Attachment 771878 Attachment 771880 Attachment 771881 |
4 Attachment(s)
Here are a few pics of when we were working on the radiator shroud cover and also while we were wiring and after we had intalled the gauges.
Attachment 771886 Attachment 771887 Attachment 771888 Attachment 771889 |
5 Attachment(s)
Here are some pics of after we had finished most of the inside and also there is a pic of the grill. You can't really see it that well but after we get the lights installed I will get a better pic of the grill. Also yes we are going with red and black interior the carpet, seats and part of the door panels will be red and most everything else will be black. After looking at what few pictures that I have taken I have noticed I need to take some photography lessons. I will try to get some better ones of the inside.
Attachment 771892 Attachment 771893 Attachment 771895 Attachment 771896 Attachment 771899 |
Wow great couple of 1st posts..
Awesome work!:metal:
Looking real good, I also used the No Limit dash panel in the 67 I did, nice work.....Jim
Thanks for all the post I really wasn't sure if this would peek any interest.
I really didn't explain much of what we have done to this point but we have put a good bit of work into it so far or alot more than we thought when we purchased the truck. We purchashed the truck with the 350 motor and frame already together. All that we did was replace some springs and install some DJM control arms on the front so that we could get a lower stance. We also coated the frame with POR15, it is messy stuff but it works great! From there we changed the latches on the doors. If you look back at the pictures you'll probably notice that the striker and the latch are swapped from what they came factory so in turn we installed electric door openers and will have fake door handles. Also Jim was right we installed the No Limit dash and what you can't see under the dash is the vintage air unit that we put in. We want to be able to get in this truck all year around and be comfortable. We also built our own console which will be different from most consoles out there because we wanted to keep the bench seats. We also installed the one piece side windows which we bought from brothers. One of the things that we are pretty excited about is the hood hinges that came from Porterbuilt. We plan to install some gas struts to go along with these hinges from Porterbuilt. One of the things I forgot to mention is the retro auto sound radio that we installed and I will get better pictures of where we installed the remote mountable USB/SD/aux. input for the system. I was really happy with the way that turned out. Some the other modifications we made were with the bed. First we couldn't find a short bed so we cut down an old long bed we had. Then we removed the gas tank in the back that was mounted in between the frame rails and built another one that is going to sit in front of the bed by the cab on top of the diamond plate floor. We also painted the floor with the UV resistant POR15. There is so many other modifications we have done that I am probably forgetting about but I will point them out as I we get farther along in this project. I will try to get better pictures so that you all can see what exactley I am talking about. Thanks for the responses and I hope that this build thread will give others some ideas for their projects. |
5 Attachment(s)
Here are some recent pics after the interior was finished, it is a bit dusty but after some cleaning hopefully it will look show quality. Also the last two pics are of the over flow tank that was picked from an old Subaru. Once we get the bracket painted hopefully it will look like a close to factory piece.
Attachment 782380 Attachment 782381 Attachment 782382 Attachment 782383 Attachment 782384 |
I like it !! need more pics.
X2!
Looking good! Nice project :chevy:
The gas tank is finished and painted. I will try to get a better picture of it if I can remember. It is a big tank but if you will look at some of the previous pictures we had a tank mounted in the middle of the frame rails on the back of the truck. We decided to scrap that because we wanted to run the exhaust in closer together so that they would come out close to the license plate.
Anyways we have moved the tank into the front of the bed and have some ideas about how to dress it up in the future. Also the idea with this tank is that in the future air ride is a possibility and we are thinking that we can build a tank that looks similar on the outside but hide the air tanks and compressors inside in a separate compartment. Attachment 784273 |
Lookin good mate, love the dash cluster and the seat! Are those old skool radios with the modern gear any good?? Looking at getting one for mine. Cheers
Posted via Mobile Device |
The radio does look good and the great thing about it is you get to keep the knobs and the older style. One thing that sold me on it was that it had a port that came with it that you can put a sd card, usb or an aux in. I carry music with me on my phone so I am planning on using the usb if we can ever get the truck to a road worthy state. I will try and get a pic of where we mounted the ports at. |
Looking good! Nice fab work.
