Attention: Anyone with a Rockwell t-case
OK now that I got your attention, I need a little bit of help. When I think my t-case shifter lever is in 2Hi, it can be moved toward the dash a bit (1/2") and it clicks, like there is the gear. But if you let go of the lever, it pops out back to where it was. My question is, is there something wrong with my t-case? I can't check to see if my front driveshaft is turning. When I think I am in 2Hi, am I in 2Hi, or is it 4Hi? I know it's not neutral because I have been driving it like this for about 3 months now. It just seems like there isn't really a separation of 2 and 4Hi, and I'd like to be in 2Hi on the roads to save on gas. Or am I just dumb? lol Some input would be appreciated, thanks
t-case question
I know that case pretty well as i have had 3 trucks with them. both of mine felt that way too but were working just fine. You are probably feeling the shifter detent ball coming up as you try to push it beyond it's 2wd position. If you have lockouts unlock them, put the t-case in 2wd & crawl underneath & your front output driveshaft should spin freely. should not turn in 4wd. if it turns but goes "click click click" in the transfer case then something is needing attention in your t-case.
Also, in my experience this rockwell burns out the bearings on the uppermost shaft easily if it is ran low on oil as the splash has quite a way to go to get to them. I filled my oil with the truck leaning on a slope to raise the fill plug a little higher to overfill it a little & that seemed to help. Don't be alarmed by some gear whine as these did that when they were new. -jeff:flag: |
thanks jeff, i'll try that tomorrow
oh and i love the gear whine...whenever a passenger rides in my truck, they ask if its gonna blow up and i just laugh |
t-221
I also have the T-221 what is the shift pattern on these ? Thanx !
Here's the shift pattern
rockwell
As a friend of mine says "coolatious"! Thanx !
My Rockwell doesn't have much movement between 2hi and 4hi. It also shifts easily without much effort. It works great though, other than leaking fluid like a sive.
Question What fluid do you run in yours? I have heard conflicting answers over the years. |
Yukon Jack, does that sticker go between the two sunvisors on the roof? Those old stickers are cool, I wish mine still had it.
I think that sticker is available through LMC truck.
I have a NIB gm part- the "trans to t-case coupler sleeve" & 68 Sub new gm gas tank straps hiding in my garage somewhere. If anybody wants either of them PM me an offer. :flag: |
That is where my sticker is. On the glove box is a worn out sticker describing the use of the lock in hubs also.
Jeffspower - what tranny does the coupler sleeve go to. I had to make one for my Rockwell to CH465 when I did the swap, as I couldn't find any replacements. |
coupler
It fits the 465. It came with a 68 k-20 sub that had the married 465/rockwell combo I had years ago. I can only read some of the GM part #39322??. I am sure it was to the same truck as I know who the guy is & can't remember him having any other old 4x4's & it was in the subs' console when I bought it. Box has the previous owner's name on it & dated 7-13-84. -Jeff:)
Hey! I got one of those stickers up above my windshield too! That must mean my truck came originally with a Rockwell case. I had no idea where that sticker came from. I always thought some one just stuck it on there because they thought it looked cool or something. Mystery solved... Thanks Jack… Pete.
Mine is a little crooked (down about 1/8th of an inch) on the passanger side. Stuck to the Glove box...
I agree with these guys.
You can check for sure even when the truck is standing still. Put it in 2 hi with the hubs unlocked, crawl under the truck and turn the front driveshaft by hand, IF you are in 2hi then it should turn freely. Then put it in 4hi and repeat and you should NOT be able to spin the fron shaft. Do this at every red light to make sure your always in 2hi Good luck |
