Trackbar problems
Ran into a little snag when I went to put my panhard bar on. I've got a 6" drop on the rear so I got the super trackbar but I'm also running a rear tank from Boyd's and a larger diff cover from ultima. The cover is too big for the bar and just wondering if I had any other options other than putting the stock cover back on?
Re: Trackbar problems
Don't know if this helps much. Best pic I've got right now
4 Attachment(s)
You may be able to run the Porterbuilt setup, nice piece for the money.
I've seen that before but didn't figure it would work with my setup. I'm not much of a fabricator either.
This one should help with your problem, saw it in a magazine on a truck that was lowered and had a large rear cover. It worked great!!!!
http://www.classicperform.com/Store/...ck/CP32021.htm |
Wow thanks! That looks like exactly what I need
:metal: No Problem!! Anytime!!
