Changing Throttle Position Sensor
I just bought an '84 extended cab pickup with a 2.8L V6 and auto trans.
How hard is it to replace the TPS. I've got the Chilton's book, but it doesn't go into much detail on removal and replacing. The reason I want to replace the TPS is because it idles a little rough, hard to get going, some times it trys to die when stopped. When you try to accelerate, it hesitates. If you pump the pedal or floor it, it will gradually accelerate; but not like it should. I know it's not a speed-demon, even if running right. I don't have any testing equipment to check codes. No check engine lights come on. |
Re: Changing Throttle Position Sensor
I have an 82 S10 with the same problem. I had to order the TPS and it will be here Wednesday. I have a Haynes manual that gives a kind of vague description as well. Once I get it and start working on it I will post what I had to do for ya.
rakerkman |
TPS are easy to replace. Disconnect it from the wiring harness. Using a torque hex driver (at least on other GM vehicles) remove the two holding screws. Install is the reverse.
To replace my TPS I had to remove the carb from the engine. Then I had to take apart enough of it that it was close to a whole rebuild anyway so I rebuilt it. If you decide to do it yourself be careful with the mixture control solenoid on the top when removing it. After removing the three bolts that hold it in use a slight twisting motion during removal to ensure that the small parts on the end do not fall off down into the carb. It happened to me and was a pain in the hind end to get them back out and put back together. i priced a new mixture control solenoid and its like a $160. Another thing that could help that I didn't do and had to trial and error it was marking where all the linkages went on the outside of the carb. I hope this helps you.
Ross |
