400 flywheel ?
I have a 79 good running 400 small block to put in my 72 K10 SWB Chevy and I have an sm465. I will need a flywheel for it for the 400. Since they didn't put in 400s in 72 in these trucks what year or type should I get? I am guessing any 12" flywheel off of some mid 70's truck would work. Will it be like finding hens teeth? I can get a new one if I have to. What do you think?:confused:
hens teeth
ive been looking for one for my 400, and sinse the 400 is an externally balanced motor, you have to find a weighted flywheel... and sinse very few, if any, 400s ever came hooked to a manual, there harder then heck to find |
If you can find a circle dirt track in your area, try talkin to them. I don't know what class or anyting laike that, but I hear many of them do the 400 small block/4 speed deal.
this is what the dirt track racers do:
http://cgi.ebay.com/ebaymotors/ws/eB...category=33616 (i asked my friend that races when i first started looking) or you can get an aluminum flywheel from summitracing.com, but its about $230ish |
I just bought a new externally balanced flywheel for a 454 from Northern in Sioux City, Ia. for $110. I don't have a catalog in front of me, but I wouldn't think one for a 400 would be much diff in price. If intersted I can get the phone # tom.
great, thanks. I asked at auto zone ( I know but I stopped on a whim) and I checked for a 79 3/4 ton truck with a 4 speed and it was about a buck fifty.
I got mine out of a 79 GMC Jimmy.
sb 400 only on that flywheel....used are hard to find! I am running a hays billet 400 sb flywheel on my 383($229 through jegs). As posted by hobby67stepside, you can get a stock replacement 400 sb flywheel through Northern autoparts for $110. It will be a 14" diam ,168 tooth ring gear, & accept an 11", or 12" clutch setup. You might check to be sure that the holes are drilled & tapped on the block for the clutch pivot ball, as most of the 400sb's were auto trans. Good luck,crazyL:burnout:
crazy longhorn, thanks. I didn't even think to check for the pivot ball hole. The Engine is out of the 79 Sierra Grande in my signature. I'll check it this weekend.
thats something i never thought about... i need to go check mine!! :eek:
I have a bud that ran into the pivot ball issue, while installing a 400 in a camaro with a 4 spd. He said the bosses were there, but needed to be drilled & tapped.......but didnt find out till it was in the car(Oops!) Good luck, crazyL:burnout:
