What shocks recommend for '69 C20??
What shocks do you recommned to keep this boat lever? We have tbe C20, 3/4 ton, and I would like some shocks that keep it from rolling so much when cornering and braking. What are the options in regard to price and quality?
Thanks, Chris '66 GMC Custom Deluxe Suburban '69 Chevy C20 Suburban '72 GMC Custom Suburban |
Re: What shocks recommend for '69 C20??
I have yet to purchase shocks for my burb, but 12 years ago I put a set of new Monroes on my 69 C10 long bed. They worked much better than the old shocks that were on it. Seems like I paid around 35 bucks apiece. Do you already have a front swaybar on your 'Burb? I have heard its one of the best bangs for the buck. I think any front sway bar from a 73-87 should fit. I have yet to do this myself but I think there is a write up in the faq section.
Hey Joe, no I don't have a front sway bar. Thanks for the tip. I bought some for our '72 and they sucked. I don't remember what they were. Got them about 1 1/2 years ago. I'd like to get some heavy duty shocks to firm it up. The springs are heavy duty, I'm pleased with them.
Call Summit and tell them what situation you are having. They have a very good tech dept.
PT |
Cool Deal, thanks PT.
Please post what you find out. I'm in the same boat. 70 C20 Burb
Chris '66 GMC Custom Deluxe Suburban '69 Chevy C20 Suburban |
Chris '66 GMC Sub '69 C20 |
Take care, Chris |
Look for monotube shocks with aggressive damping especially bump / compression. KYB Gas Adjust are perfect for this application, very stiff on the rear of a unloaded truck though
Chris '66 GMC Suburban '69 C20 |
Bilstein HD shocks....can't beat German engineering so obviously a little pricier than most other brands. plan to get a set for my 72 Burb C20 some time over the winter. not sure if Summit carries the correct part numbers for our trucks yet (particularly the trailing arm rear suspension) but here is a link to a seller:
http://www.eshocks.com/bil_Ind.asp?VC=4Q81&SubChar=Q my truck didn't have a sway bar either. i fixed that with one from CPP (and matching rear unit not yet installed) but the 1-/4 front bar off an 80's 1 ton or camper special is an awesome upgrade. just be sure to get the drop down brackets for the frame rails, bushings, and clamps from the a-arms. |
Thank you, I plan to get them and the sway bar. I may get a complete front end from a '79 3/4 ton.
Chris '66 GMC Sub '69 C20 Sub |
not sure if the 3/4 ton burb has the biggest sway bar or not but still a good source of parts to upgrade your rig. you can measure it with a pair of dial calipers. my dad's 84 and 87 burbs had the 1-1/8 bar. i think the original 67-72 bars may have been smaller than that. the big sway bar is much rarer but shouldn't cost you any more (an old sway bar is an old sway bar to most junkyards).
that's not a bad deal on the parts. but do you need to swap the whole front end? is your truck a 69 or 72? if it is a 72 then it should have disc brakes on the front. i know my 72 burb c20 has powerful brakes to begin with and with the Hawk carbon-ceramic sever duty pads they REALLY bite down. the benefit of parts from 1979 is nill unless you are starting with drums. in that case you'd want more than just the sway bar stuff.
I may pick it up to do the swap later. Chris |
Just heard from a coworker that he doesn't mess with anything other than Bilsteins on any of his vehicles. Said he put a set on a 3/4 ton truck awhile back and the difference was night and day and he plans to put a set on his current chevy pickup because they are better than even modern factory units. This guy also owns a late model Mercedes convertible, so you could say he is serious about having a cushy ride!
I have spindles and rotors for a 3/4 ton sitting in my shop they are yours if you want will be pulling a good rear axel if you are interested all you got to do is drag them down Yorktown
Posted via Mobile Device |
Regards, Christiaan dukecac@aol.com |
Pulatoy@gmail.com
