Wide tires
What is the widest rim and tire combo i can put on back of 64 c10 without narrowing rearend?
Re: Wide tires
Fleetside... assuming you have stock rear axle...8x15 275x15 or 10x15 if you roll the inside fender bead.....
Re: Wide tires
thanks for the reply...yes stock width axle shortbed fleetside..i have taken measurements and think its possible to run 12 wide rim with 325/50/15 tires but not sure of backspacing..do you or anyone else know?..also its a 64 assuming the rearend was never swapped for another year..also some pics from anyone would be helpful...thanks :)
Re: Wide tires
Moved the thread plus a bump to the top.
Re: Wide tires
http://i112.photobucket.com/albums/n...y/DSC_0390.jpg http://i112.photobucket.com/albums/n...y/DSC_0392.jpg |
Re: Wide tires
http://67-72chevytrucks.com/vboard/s...d.php?t=443520
A couple more threads on this |
Re: Wide tires
Br3w city...thanks for the pics and info...i wasnt exactly sure on b.s. If 7.5 or 8 or 8.5 would work but now i see...thanks alot
Re: Wide tires
Most rim shops don't like backspace that large, you usually have to ask, but I have seen them up to 9.5" of BS. That would be nuts to me. 8.5 is really pushing it, and (at least with a steel sectioned wheel) narrows the center of the barrel, so brake clearance become very tight. A big part of fitment is the tire choice, if you want to run a non-radial, you might want a bit more clearance. The ET street radials I run have surprisingly little "bow" out under the weight of the truck. I have about 1/2" or so on the outside, and could roll the fender a bit if I needed to.
If you want to go that big, you HAVE to remove the e-brake cable from the drum. It interferes with the rim |
Re: Wide tires
thanks for the info... i have found some wheels from centerline and weld with b.s. that will work but of course in 5 lug which i plan to swap axles from early classic enter. later on..i ran the mt et drags on a mustang i had and they did ok, but for the truck i was looking at bfg drags for it and yes they do balloon a bit more though and my e-brake cable is already removed...i guess i really need to take more pricise measurements and research my tire options a bit more...just wanting a good looking wheel and need that traction width!
Re: Wide tires
2 Attachment(s)
I'm running the stock truck rallys 15x8 with 305-50r-15's on back without any problems .. Once they are wore out I will be switching to the 275-60r15 tires ..
Re: Wide tires
Re: Wide tires
I'm running 15"x8" with 4" backspacing and my wheels are perfectly centerd with about an inch on eather side. P235/75/R15 tires.
Re: Wide tires
Re: Wide tires
Cut the rear end 4" on each side and installed new ,Moser axle's. These are 15"wide mickeys Thompson's tires on a 15 x12 rim with a 6.5 back space. Did cut the bed and use fleet side tubes in the bed.
http://i700.photobucket.com/albums/w...ps26207297.jpg http://i700.photobucket.com/albums/w...pse125cb96.jpg |
