292 Brackets and Power Steering/HEI
Is there any value on 292 brackets for power steering? Complete bracketry including pump. It is on a step van but I do not believe the brackets are different from a Pickup?
What is range of value on P/S set up? What is range of value on 6 cyl HEI? Thanks, Alan |
Re: 292 Brackets and Power Steering/HEI
Do a search in the sale section to get a idea of a price range.
292 P/S brackets don't fit the more common 250's, but the brackets are not all that rare as many 292's were equipped with P/S. Do you have the full set including the alternator bracket (if the alternator is on the driver's side)? Or is it one with the AIR pump above the P/S and the alternator on the other side (less desired it seems)? IIRC a full set with alt brackets goes in the $35-50 range. The AIR version seems to go $350 for the set. If you only have the cradle and not the upper brackets, there really isn't a market. For perspective, an eFlay seller has a new custom design for ~$125, ready for paint.
HEI, $25 tops. $15 most of the time. Depends on if it is the coil in cap or divorced coil version, and which one someone needs. |
Do you still have the P/S brackets?
Here is what I just sold on Ebay
http://www.ebay.com/itm/270942771757...84.m1562.l2649 |
