'69 350 id?
I have a '69 burb, and it has a 350ci in it and also was originally 4 speed on the floor. The engine block casting # is 3970010, and the front pad is stamped V0711CHA. From the the Year-One site, this stamp translates to Flint plant, July 11th, C is type of engine, and the HA is the suffix code, which translates to 350ci, 300hp, 4 bolt main with manual trans. Does this sound right to you guys? Thanks in advance!
Re: '69 350 id?
The suffix code for your engine is CHA, not just HA.
