84 Blazer 6.2 Diesel???
looking at a 84 blazer disel. Are they worth it... are they reliable and do they have any power... what kind of milage with a lift and 33's Or would it be better to get one with a 350 engine
Re: 84 Blazer 6.2 Diesel???
I like mine. The power is good and the mileage excellent. I can't measure mpg because I need to replace the speedo cable but a fill up lasts way longer than it should. I don't have lift/33's on mine yet but I can't imagine this motor caring. Mine is a CUCV so it's got the TH400 transmission. If you're looking at a civvy version, the TH700R4 would be better on the hwy.
not sure which model this is but going to check it out tomorrow. Just didnt know if it was better to get a 350 or a 6.2
Im a recent 6.2 diesel convert. I have a 84 3/4 ton suburban with a 6.2/700R4 combo
It gets great mileage with 35" tires, I haven't checked it to see exactly what it gets but I'm guessing close to 20mpg Posted via Mobile Device |
I get anywhere from 13-17 mpg in my 91 burb with a 6.2 and the banks sidewinder turbo on it. It has a 700r4 trans, a 6 inch lift, 4.56 gears, 37" bfg km2's, and it is running strong at over 200k miles.
http://i824.photobucket.com/albums/z...1296693408.jpg Posted via Mobile Device |
I'm a new fan of the 6.2L in my M1009/K5. If at some point you replace the Injector Pump, get the pump for the 160hp "J" code engine. The Blazers only came with the 130hp "C" code (except for military).
so what will it take to get some more HP out of it. I have been pretty versed i the cummins and dmax world. So what HP upgrades will make the truck more powerful but noit breaking the internals
J-code intake
Turbo Better flowing exhaust. In my Burb I advanced the IP a tiny bit, I could definitely feel a difference. You can also turn up the pump a bit (it's a required mod with a turbo) I'm told the 6.2 with banks turbo HP and torque are similar to a stock 12v cummins, I have no real world experience though... Posted via Mobile Device |
I'd leave it stock for reliability. That's what these were built for and that's what they are. I had an '84 with the Banks Sidewinder kit and it was running fine when I sold it with nearly 200k on it. But,that was back before they decided to sell diesel for more than gas. It didn't feel a whole ot more powerful than n/a. I guess adding some power is ok,but don't try for a whole bunch. Also,why lose fuel economy? That's why I run them. My '91 Suburban with 4.10s and 4L80E could roll down the hiway at 75 mph all day and get 20-22 mpg with 35" tires. I feel the power is adequate with the 6.2. It moves along just fine.
