Blazer roll bar
Blazer roll bar $150Attachment 880923
Re: Blazer roll bar
what year is this out of?
Re: Blazer roll bar
I pulled it from a 73 or so a while back. I put it in my 70 and took it out. It fit fine and i like that all legs bolt to the floor instead of the wheel wells like some 69-72 ones do . Its has the identical shape as the dealer add on 69-72 ones just the rear legs are diff and has shoulder seat belt spots. it will fit directly between the pillars or you can set it back tword the wheel wells . Some one might know better than me on this but im pretty sure theres not such thing as a factory 69-72 roll bar but 73 and later maybe factory cause this one was threaded on the floor of the blazer where it was bolted looked like factory deal to me ! hope this helped
Re: Blazer roll bar
This is a tempting deal. Are you looking for anything to trade?
Re: Blazer roll bar
Depends i guess ,i could use some rear seat front two hold downs and im looking for some good clean 1/2 ton stainless front 4x4 dogdish caps im waiting to hear from another member on the hubcaps. Or i could cut you a package deal on a set of buckets and the rollbar
Re: Blazer roll bar
I would like to get in line behind Woodymm3 IF you can deliver to Harrison the next time you are in town.
Re: Blazer roll bar
I will take it (the roll bar)...per the prior the message.
Re: Blazer roll bar
I am about six hours away and dont come home to jonesboro exept like every three months so if walleye wants this than I concede. It is a good deal.
Re: Blazer roll bar
sold to walleye
