68 LWB 250/3spd
4 Attachment(s)
I'm almost afraid to ask because I know the 6's don't bring as much as the 8's, but I just did a lot to this truck and curious what you all think it's worth.
In the past 3 months I have: power steering w/ correct pump brackets, new lines converted to power disc front (new calipers/rotors/bearings etc) 5 lug conversion in rear with ECE shafts New rear shoes/hardware/drums/cylinders Added sway bar w/ new bushings Complete suspension/steering overhaul(springs, shocks, tie rod ends, control arm bushings, etc.... kit from LMC) Engine gasket kit installed including rear main rebuilt carb new fuel pump skip white HEI new clutch/pressure plate new u-joints, carrier bearing, driveshaft balanced new door felts Lots of little things replaced that i can't remember Only thing that doesn't work is factory radio |
Re: 68 LWB 250/3spd
Nice truck! I would say in the 5-7k range depending on the quality of the body and paint work. I like the sound of a six popper! Sharpie
