Converting to Hydraulic Clutch ?
I am building a 70 c10 and dropping in a 350 with a T56 trans, issue at hand it how to go about converting to a Hydraulic Clutch
Option 1: Out of the box kit from American Powertrain (~$380) Specifically built for the c10 and the t56 setup, from what i understand bolt up and go. http://www.americanpowertrain.com/GM...hydraulic.html Option 2: Complete build it yourself as shown by TR65 (~$100) not specific to the truck or the trans complete build from scratch. http://67-72chevytrucks.com/vboard/s...d.php?t=300087 Option 3: Retrofit a 93-95 Camaro clutch setup to my 70 c10 (~$150-$200) specific for the trans. The t56 BW came out of one of these Camaro's but it is not specific to my trucks pedals http://www.rockauto.com/catalog/moreinfo.php?pk=1568224 Option 4: any other suggestions Questions. comments or words of wisdom welcome. |
Re: Converting to Hydraulic Clutch ?
Can you use a hydraulic setup out of a 85 and newer square body including the bell housing?
Using an newer clutch assembly is that pretty much bolt in or is there a fair amount of mods needed?
I haven't done it but I would think it shouldn't be too hard to fab a pedal and master from an 88-98 truck since the clutch pedal is a seperate unit from the brake unlike the square bodies. Like I said I haven't done it but I think it's the route I would attempt if I was going to.
Any updates? Which route did you go?
