Parting out 72 K10
5 Attachment(s)
Parting out a 72 Suburban K10 350, TH350, NP205, and 3.73 gear This thread is for all the parts that are common to both the Pu's, Suburban's, and Blazer's. All prices are plus shipping.
All the following parts are hot tanked and dipped. 4x4 trans-tcase cross member. 75.00 Engine cross member. 75.00 this one sold, have 2 more Shock mounts. 12.50 each Rear spring hangers with supports. 35.00 each Front disc brake stone sheilds. 85.00 pair sold 71-early 72 spindle. 50.00 Tie rod with tight ends and straight. 45.00 sold Rear u-bolt plates. pair 25.00 RH axle 71-early 72 needs u-joint. 65.00 LH axle 71-early 72 inner half only. 35.00 T-case support. Mounts to the t-case and RH frame rail. Needs rubbers. 40.00 T-case adapter rubber mounts complete and original. Nice condition. 30.00 sold Front spring shackles. 20.00 Chrome T-case shift stick with knob, boot, ring. nice condition. 110.00 sold LH chrome vent window. Chrome nice, vertical divider rubber bad other rubber driver qaulity. 40.00 sold RH chrome vent window. DQ rubbers, 45.00 More to come. |
Re: Parting out 72 K10
Will you seperate I just need T-case shifter boot, ring.
Can I please see a close up pic of the chrome on the drivers side vent window.
I will take the transfur case adapter plate mounts and the disc brake backing plates as long as the backing plates are nice and not all banged up thanks
Tom, I'm needing a nice 4 speed shifter knob. Thanks Randy
Any chance you have all the auto tranny linkage parts to the carb?
I'll take the tie rod. Thanks, Pete
I'll take the brake dust shields as long as they are straight and not damaged.
Can I get some better pics? |
how much shipped for the trans crossmember to 35960. will take it pending price shipped ?
I'll get back to all in a couple hours. Thanks
Hi Tom, Id like to put my name on the a/c vacuum pod bracket. Thanks Josh
Do you have all 4rear spring hangers? If so give me a shipping quote to 24556. Very interested.
Thanks Posted via Mobile Device |
Thanks to all, Tom |
Thanks, Tom |
Sounds good Tom, I'll be busy around here this coming week anyway, getting ready for a swap meet Fri and Sat. Thanks Randy
I get me a price on shipping, it ok I can wait till next week on the quote. Thanks pending shipping I am still interested in all 4.
Tom - I think some of the tranny linkage parts may be 4x4 specific - need whatever ya' got as PO removed it all from my K10. Thanks, Pete
I will wait to see what the stove pipe looks like befor you get shipping on the boot and ring. Gary
I'll take the vent windows. Price shipped for both to 23112?
5 Attachment(s)
pics as requested
5 Attachment(s)
More Pics.
4x4 fan shroud. 45.00 sold 3 core radaitor. Looks to be a recore with original Harrison large tanks. Looks very nice. 75.00 |
