What did you do to your truck today??
Seems to be a lot of questions which is fine but did anyone add anything or do anything to their truck today?? If so what did ya do? Oh and pics make it all better :lol:
(Couple days ago) I got closer to getting this thing running, fixed some wiring, swapped out torque converter for new one (new trans old converter, i knew better) modded trans mount to fit 4l60 (had bb and 4l80) Installed exhaust, driveline, finished up the front suspension swap to 5 lug and all new calipers, rotors, hoses and bearings http://i276.photobucket.com/albums/k...429_122259.jpg |
Re: What did you do yo your truck today??
nothing.... its sitting back at the company yard/terminal in so cal, and im in texas (im an OTR truck driver). but when i get back its gonna be needing a motor put in it :(
Posted via Mobile Device |
I started my 6 inch lift install. got the back done so far.
http://i114.photobucket.com/albums/n...6835872333.jpg http://i114.photobucket.com/albums/n...6835879152.jpg http://i114.photobucket.com/albums/n...6835897831.jpg1 |
tore my front end apart for a rebuild.
pic proof on the front end..
http://img.photobucket.com/albums/v3...4/100_4145.jpg http://img.photobucket.com/albums/v3...4/100_4149.jpg |
I put a "new to me" center console in it from the swap meet. Tonight I'll be putting in my open element air cleaner.
Fired up the crew cab and let it take its first breath of air, sounded good so far!
But today i had the day off and played with my 97 sierra. I rewired my headlights so now when the highbeams are on, all four lights light up. And i put on a led 3rd brake light ive had sitting around for a year or so lol. |
Took the bed off to replace the fuel pump module and did a rust conversion and chassis paint job while I was there.
Purchased a turn key, low mileage 5.7 / 4L60E combo to replace the tired 5.7 TBI / 700R4 drivetrain. :bann:
Posted via Mobile Device Posted via Mobile Device |
Ripped apart a parts truck so i can split the parts between the X and crew cabs.
http://i276.photobucket.com/albums/k...525_204043.jpg http://i276.photobucket.com/albums/k...526_180711.jpg pulled the bed off the crew to use new bed and rear section of the frame. http://i276.photobucket.com/albums/k...526_173628.jpg |
Scott I wish I knew you were needing the rear half of frame and short bed for the crew. I have just what you need, in great shape too from my wrecked 97 GMC.
http://i276.photobucket.com/albums/k...531_193741.jpg |
right now I'm working on my body work underhood. I got the inner fenders done yesterday and the bottom wheel side of them painted, same as the frame and susp. up front. The top side has been primed, waiting on the bottom to dry up today then hopefully wetsand and paint the top engine side tomorrow.
I'll post pics later. |
Spent almost 200 hours working on my 1994 Cheyenne in my gravel driveway just on the fine weather days since mid March. Rains a lot here so sunny days were 10-12 hours of work.
PARTS 2 new tires(10.5X31X15) 2 perfect doors from parts truck(with mirrors) 4 door pins, bushings and clips 1 fender from parts truck(repaired) 1 rear wheel tub from parts truck 2 cab corners(inner) 2 cab corners(outer) 2 rocker panels(inner) 2 rocker panels(outer) 2 patches in floor(one sq ft) 3 cab mounts(from GM dealer) 2 sway bar end links 4 shock absorbers(and bolts) 1 front caliper 1 set of brake pads(front) 3 brake lines 1 bleeder screw 1 ball joint(upper) 1 dome light switch MATERIAL 4 cans weld-through primer 5 cans Tremclad(flat black) 2 rolls MIG wire(2lbs each) 4 zip cut discs 2 cans rocker guard 2 cans undercoating http://img.photobucket.com/albums/v4...2/SSPX0573.jpg |
left it still sitting in the parking lot at work back in cali (im in kentucky right now) so its still waiting for me to get back so i can do the motor build (finish) and swap it all in a period of 6 days along with a bunch of other crap....
pics of what I did today...
http://img.photobucket.com/albums/v3...4/100_4188.jpg http://img.photobucket.com/albums/v3...4/100_4189.jpg http://img.photobucket.com/albums/v3...4/100_4187.jpg http://img.photobucket.com/albums/v3...4/100_4190.jpg http://img.photobucket.com/albums/v3...4/100_4193.jpg http://img.photobucket.com/albums/v3...4/100_4191.jpg http://img.photobucket.com/albums/v3...4/100_4192.jpg |
wow how did I miss yesterday?
well heres today.. http://img.photobucket.com/albums/v3...4/000_0251.jpg http://img.photobucket.com/albums/v3...4/000_0250.jpg http://img.photobucket.com/albums/v3...4/000_0249.jpg http://img.photobucket.com/albums/v3...4/000_0248.jpg http://img.photobucket.com/albums/v3...4/000_0247.jpg |
Nice! looking forward to seeing how you did the firewall and seeing it finished
glad you posted cuz I got more pics...
http://img.photobucket.com/albums/v3...4/100_4210.jpg http://img.photobucket.com/albums/v3...4/100_4216.jpg http://img.photobucket.com/albums/v3...4/100_4214.jpg http://img.photobucket.com/albums/v3...4/100_4215.jpg http://img.photobucket.com/albums/v3...4/100_4220.jpg http://img.photobucket.com/albums/v3...4/100_4217.jpg http://img.photobucket.com/albums/v3...4/100_4223.jpg http://img.photobucket.com/albums/v3...4/100_4218.jpg couple pics of the flake http://img.photobucket.com/albums/v3...4/100_4224.jpg http://img.photobucket.com/albums/v3...4/100_4228.jpgd you |
Looks great. definitely gotta consider doing that to my truck now. was it hard to mask everything off?
nope you see how masking it is, a rug/throw over the motor, and some tape on the radiator sides then on some hoses and cables and such, only until they fell under the cover, then I did nothing else to them.
Here's the kicker, that's spray cans, so less over spray and easy to get in and use in tight spots. It was around the same price if not cheaper then using quarts and such. before anyone gets any ideas, this IS auto paint, it was mixed at the body shop supply, and it's single stage with hardner just as you'd spray from your paint gun so yea it'll last and it'll hold up great. I bought 5 cans, used 4, $17 a can(some were cheaper for some reason, like when I bought more then one thing) so I got roughly $60-70 in what I done, not counting primer and filler, or sand paper, primer was spray cans, used 3 kinds, all rustoleum brand, used self etch on bare metal, filler primer on body work areas, then used some black on the firewall, made my paint cover better and faster being dark. Now quarts and such run you roughly $50 a quart or more, then you add in reducer, which in my case for the base coat I got to use on the outside of the truck is $10 a thing, then hardner is usually $25-50 a pint can, so yea it costs more that way, plus everything and I mean EVERYTHING! has to be masked off due to overspray. I should have masked more, I got some on the window and front chrome, but hey thinner brings that off easy. I'll just touch up my frame with some black and that'll fix it. |
Thanks for the run down. looking forward to doing this myself now. definitely want to see it when youre all done
