For Sale 11/4" Sway bar 67-87
just back from the mailbox fex ex box waiting for me... Well .. i bot it on Ebay ...This is a factory 1-1/4" front sway bar I got off a 78 Chevy 3/4 ton 2wd pick-up. This auction is for the sway bar only. This bar will fit all 67-87 light duty 2wd trucks (C10/C20/C30). This is the largest diameter sway bar GM put on a light duty truck. This is a nice upgrade from a smaller diameter sway bar. If needed, the frame brackets and bushings can be purchased from the GM dealer or from the aftermarket. The sway bar has some minor pitting in the bushing areas but not enough to effect its performance. I cleaned the bar and painted it. It is not a show quality finish but will be fine for a daily driver.
BUT i got my 71 c-20 last sat.. and pooof it Has a orig sway bar on it .. so $29.99 + s/h For estimating shipping cost: The bar weighs about 29 lbs and will be in a box with the following approximate dimensions: 17.5" wide, 3.5" deep, and 44" long.my ZIP is 14450 NY so help please ..if you need a pic email reply to HUGHNEWS1@AOL.COM thanks |
