Seat for a box
Situation, I have an 88 Burb with removable 3rd row seating and want to install a system. However, it will be parked in an area where I'll need to keep the system hidden for safety reasons. Does any know if a removable third row seat can be turned into a speaker box? If so, how difficult is th his to do?
Posted via Mobile Device |
Re: Seat for a box
Tint the windows and never turn it up loud around your house has worked for me for years.
Re: Seat for a box
His truck isnt the most secure so he dosent advertise it... |
Re: Seat for a box
one of my buddies has a newer burb..iirc like a 96 andways he removed the 3rd seat.. and went junk picking found a broken dresser.. then took the draw faces off the draws
and glued them to the dresser.. brock off a leg and removed a few of the draw pulls hardware and glued down the rest so it not rattle.. and this covered his box for years.. as anyone the looked in only saw a broken used up dresser.. worked like a charm |
Re: Seat for a box
Re: Seat for a box
Plan B buy a shotgun and clean it on the front porch once a week works good too.
Re: Seat for a box
hay you laugh.. he had the stock rims jacked, but not the audio |
Re: Seat for a box
do shallow mount sub in tha back door(s)..a lil tint..color match tha grills to tha panels..folks would never know they where in there unless you turn em up.
Re: Seat for a box
I did eight 8" subs in the bench seat of an extra cab Silverado, you can do the same in the burb. The cover over the speakers was modified for more air flow, but it looked stock, as was the goal.
Re: Seat for a box
I don't know if this is what jimmydean was suggesting, but you could pull the cushion/springs out of the bottom of the bench and design a downfiring enclosure that mocks the bottom of the bench and just put a little padding and the upholstry over it. Won't be the most comfortable thing to sit on, but it'd never be you probably...lol
Re: Seat for a box
Know where I might find any plans, diagrams or instructions on pulling this off? |
Re: Seat for a box
Man...this sounds like a fun project! I don't have any plans/diagrams, but how different is the rear bench of a Burb to the rear bench of a Blazer? If they are the same (Mine is 1st gen though), I can measure mine out and get you some dimensions and designs.
In my mind, you would use all the existing mounts mounts, arm rests and what not and have the speakers downfiring. It'd be a fairly small box, so maybe 8's would be best...but if you invertered the speakers (considering there was enough room under the seat for the magnet) you could possibly get a set of 10's in there. |
Re: Seat for a box
We actually built the box as the back of the seat with padding around the subs. The bottom would work as well. Our seat looked like a stock '88 extra cab bench, only the middle part was full of sound.
Re: Seat for a box
I'll take some measurements tomorrow (and pics to boot) so that you can get an idea of what I'm working with... however, I may run into problems with the subs as the ones I'm working with are a set of 12" Boss Audio 1200 watt subs. So if I can make em fit in the seat, somehow, the rear passengers will be a bouncing! LOL
Re: Seat for a box
Oh yeah...12" subs won't be the easiest thing to get in there and still retain the correct amount of volume required for those. Does the specs on the sub have a preferred amount of volume for a sealed enclosure?
Re: Seat for a box
Re: Seat for a box
I did a box for my buddies Bronco with 2 15" Orion XTR's. The box was on rails and fit behind the rear seat. If you flip the seat forward, you could slide the box forward to give you more "trunk" space. Worked out well. Just used some heavy drawer roller rails and floor mounted latches to lock it in place. Took all of a minute to unlock it, slide it, then lock it back down.
<edit> Or you could take it out all together if you needed to. |
Re: Seat for a box
It would make for a very heavy seat and a semi-complicated design, but you could incorporate both the bottom of the seat and the back as the enclosure for additional volume...just a thought. However, with a speak with that rating, I'm guessing the overall depth is greater than average and fitting inside an enclosure that shallow may not be possible...
Re: Seat for a box
Speaker: Full height 7 1/2" (top of cone-bottom of magnet) with a Diameter of 12 1/4" Seat: Depth(including space under seat): Tallest point about 9" to a shortest point of barely 6" Diagnosis - Darn.... So I guess it's time to explore other options now. If I had a car I would just leave them in the current box, hook em up and go on about my business. Anyone have different ideas about how to hide a set of " Boss Audio RIP 220 DVC " subs in a Burb? |
Re: Seat for a box
How about a box on the side maybe made to look like a tool or storage box.
ALL my stereos are pretty well hidden after my Toyota was stolen years ago. The only thing you will see in my truck is the door pod tweeters. |
Re: Seat for a box
Hiding 2 12's as big as those is going to be a task. I like jimmydean's idea of making it look like a toolbox, or maybe even an ice chest.
Another option is to build a box that's 8" deep internally and build a false floor in the back. This would make the floor raised to about 11" or so depending of the Xmax of the speaker...may not be ideal but you'd never have to remove it to put stuff back there...just right on top of it. |
Re: Seat for a box
Were the false floor idea the one chosen, I would consider putting the false floor under the middle row of seats as the gas tank is under the floor in back. |
Re: Seat for a box
Oh, I like the false floor idea!
In my 4Runner, I did a 10" on each side. I built out the sides a little, but it looked stock. There is a storage space on either side of the 4Runner ('88) and I built speaker grills that looked just like them (had the knob and everything). Nobody had any idea. |
Re: Seat for a box
Re: Seat for a box
Just think of a raised bed most guys (like I will be doing) do to cover the notch in the back and have a solid floor without the hump.
You could raise the whole floor of the Burb about 6" (or whatever would clear the back of the sub with a little room) then you mount the subs in the floor either in the corners, or along the side so you don't cover/hit them with stuff. You could do it smack in the middle to, just make sure you do some sort of a screen or grill. My brother and I built an '88 SS truck that had 4 10" Nakamichi subs mounted under the truck in band pass enclosures with the ports running up into the floor behind the seat. It won IASCA 100W pro class Nats and was the first of its kind. Not the most practical, but it was cool as hell. Boxes only hung 1" below the frame (truck was a hot rod, not low and slow). You can make it out of wood, then fiberglass it to make it weather resistant. All I use on my builds are a table saw, jig saw, Dremel, and drill. |
