Corvette (Ls6/bat wing) oil pan
Has anyone run one of these in a C10? I can pick up one for pretty cheap, but not sure how well it will clear the crossmember. I'm sectioning 2" out of the xmember and can notch it slightly, but Im wondering how the fitment might be around the frame and fbody headers. If it wont go I'll just go with a fbody pan.
Re: Corvette (Ls6/bat wing) oil pan
Those pans are cheap for a reason, they almost never fit anything but a corvette. F body pan is generally more user friendly.
Posted via Mobile Device |
the bat wing pan is one of the ones needed on most conversions, the other ones that i see that people want are the pans that come on the trucks, i wish i could tell you about the clearence but i cant, you might check on ls forum they have alot of great info there for just about any kind of swap.
Rumor is it will hit the lower control arms...
You can make a Vette pan work, The engine/trans has to be moved up. I put a 5.3 in a lowered 71 C10 back in 02 & used a Vette pan, The oil drain points right at the cross member, It holds 7 quarts of oil....Makes oil changes interesting & expensive.
If I had to do it over I would use this http://www.summitracing.com/parts/NA...2593/?rtype=10 Comes with a pick-up tube, windage tray, dipstick & tube, & bolts.....New GM stuff for $150! |
ttt for this one, not much info and I can't find any pics of a batwing pan in a c10 anywhere.
Anybody else try the vette batwing with 87+ dirty dingo slider mounts in a 67-72? I don't have the pan but if fits I can get one cheap. |
