Parting out 69 C20 PRICES LOWERED!!!
Got what's left of a '69 C20 to part out. Cab and bed sheet metal was junk, so that's gone to scrap metal. Here's what I have off so far:
Headlight trim, straight light surface rust sold Fender emblems, some over spray, easily cleanable SOLD Front turn signals with lenses sold Gauge cluster, nice printed circuit, everything works SOLD 4 row radiator clamps, rubber good. sold Headlight buckets with springs and adjusters sold Tailgate trunions 10.00 shipped Ball bearing ashtray, crappy paint job, but works great! 10.00 shipped Lighter, headlight switch, and wiper switch with knobs, headlight switch looks fairly new. tiny bit of over spray on lighter trim that will clean right off. All in working condition SOLD Hood latch with support. Nice and straight, works fine 25.00 shipped Brake booster w/ proportioning valve and master cylinder. For drum brakes, works fine. SOLD High hump trans tunnel. Very nice!!! With bolts SOLD Saddle seat belts, needs cleaning, pitting on chrome on 1. 1 buckle has a little cracking SOLD Saddle visors, very nice SOLD Aqua blue/ green visors, very nice SOLD Chrome 1 wire alternator, working condition, don't know the amperage. dsSOLD 4 row radiator. Aftermarket, appears to be recently replaced. Fins are perfect. Very nice. SOLD Left fender, very clean, no dents, cup is good. PO screwed front molding in with 2 small screws, otherwise really nice shape SOLD Right fender, same screw holes, but 4 instead of 2. Cup has rust, but the rest is very nice. SOLD I'll be adding more as I get it apart. If you don't see it, ask, I might have it!! https://lh4.googleusercontent.com/-R...8/IMG_4404.JPG https://lh6.googleusercontent.com/-O...8/IMG_4405.JPG https://lh4.googleusercontent.com/-Z...8/IMG_4406.JPG https://lh5.googleusercontent.com/-o...8/IMG_4407.JPG https://lh3.googleusercontent.com/-u...9/IMG_4413.JPG https://lh5.googleusercontent.com/-U...9/IMG_4414.JPG |
Re: Parting out 69 C20
I will take the emblems if the studs are intact.
Engine stands? |
pm sent on the emblems. thanks, Scott |
i'll take brake booster
I need the part of the floor where the high hump cover bolt to if you still have the cab ?
Interested in the lighter and switch set. Do you have the wiring harness for the lighter? Is the headlight switch a gm part?
Posted via Mobile Device |
I'll take the seat belts. PM me your payment info.
Hey scottg I was mostly concerned with the knobs looking the same including the brushed metal inserts. Do they? Would all the parts clean up real nice? Does the lighter assembly have a light? Just curious. Thanks
Scott |
I'm looking for a bellhousing #3925505
I will take the cluster. PM me with payment info
Do you still have the big block power steering hose
Paypal sent. Thanks
Hey Scott, I'll take the lighter w/harness and switches. PM me with payment info. Thanks
Thanks Scott, I need the 5 inch opening, not the 4.xx inch opening.
