Please Help with part
Does anybody know if, on a 68, this part (the center strut that goes across from shoe to shoe just under the wheel cylinder) is on the front drum brakes? It's the orange part in the center of the pic.
Attachment 1005351 |
Re: Please Help with part
isn't that the bar for the emergency brake?
yes e brake arm
whew, ok. That isn't my problem then. Thanks!
Pic of the front brakes on my 70 if that will help
Awesome, thank you!
Let me know if you need more, I just did the front brakes and took a bunch of pics. I think your problem is you reversed the direction of the cap that holds the shoe retaining spring. It will cause what you are describing in the other post.
Do you mean I flipped it over?
Also, on the retainer with the red arrow that has check next to it. Is that the short or longer spring? Thank you sooooooo much for the help! |
Not sure about the springs I'd guess the short spring goes to this side |
Ok, thanks. I know they are dished and the dished side goes down but I did have another that goes on the adjuster arm under the spring and then the standard retainer on top. The retainers seemed designed to seat in the springs.
Different angle, disregard the pointing finger
(Thx for all the help.) Now I get it.
Did you get the brakes working right?
I haven't got to go back yet, it will be tomorrow when I do then I will post an update. Thanks again for the help secretsquirrel.
no worries :metal:
