Help Identifying 4l60e Trans
I've searched both the web and this site and I can't seam to decode the identification code for a 4l60e trans I picked up at a junkyard. There is a paper tag on the drivers side rear that has
04CHD on the top of the tag with 04CHD708155259 below Thanks for any help you can provide. |
Re: Help Identifying 4l60e Trans
Im familiar with 4CHD....Which stand for 04, C1500, 4L60E.
The "0" in the front is odd, Maybe a rebuild number??? Got a picture of the tag?? More info..... |
Sticker ID thats usually on the top of the case....
1 - 4 = 2004 2 - Model 3 - Hydra-Matic 4L60-E 4 - Transmission Asm. as Shipped Number 5 - 4 = Model Year 6 - Julian Date or Day of the Year 7 - Letter After Julian Date Identifies the Plant Shift Build 8 - Bar Code 9 - Serial Number 10 - Broadcast Code 11 - Transmission ID 12 - Build Location Y = Toledo, OH, R = Romulus, MI, 4 = Ramos Arizpe, Mexico |
The tag is hidden behind a bracket. I'm going to put this behind a 5.3 Vortec is there anyway to tell if this transmission came out of a V8 or a V6
http://i76.photobucket.com/albums/j3...3/100_2864.jpg |
Never seen GM put a sticker there on a 4L60E. Rebuilt a couple hundred of them.
Check here.....& report back.... |
It's stamped 6CHD037
Posted via Mobile Device |
06 C1500, 4L60E. Or at least the case is.
Are you going tear it down & check it out? |
I don't plan on having it rebuilt, I'm going to change the filter and cross my fingers that it's good. Thanks for your help
My 4L60E is stamped 7KCD121B. KC is the engine code, but for which engine?
What does 121B tell me? I know the year is 1997. It’s a 1-piece bell housing/transmission. The KC may be KG, some wear in the pan rail. |
